how to adjust lean/richness on a Q-Jet?
Old Mar 22, 2002 | 11:58 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i think my car is running rich....how would i b able to adjust this?
thanks
Old Mar 24, 2002 | 08:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is it always running rich, or only under certain conditions? Is this a CC or a non-CC carb?
Old Mar 24, 2002 | 01:20 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
it seems like its always running rich
and its the stock CC q-jet
Old Mar 25, 2002 | 01:50 PM
slowV8berlinetta's Avatar
check your choke first. Is it worse at startup? that would make it more likely to be choke related, but if it's all the time check your vacuum sensor too. if it is not working or the vacuum line to it is cracked or not existent you will not have any distributor advance and you r fuel curve will be screwed up. When my line was snapped i had horrible driveability problems, failed emmissions, and was getting 12-13 miles to the gallon. It cost me less than 2 bucks to fix it.
Old Mar 25, 2002 | 09:59 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah its worse on start up
and is that vacuum that you are talking about at the back of the carb...cuz that line doesnt seems to come off really easily so maybe it is messed up or something
and my secondaries arent opening all the way...only a little bit.... and i have to basically floor it when i start it up or it will die
as for mpg.....my car seems like it chugs gas no matter what
lol
Old Mar 25, 2002 | 10:20 PM
firepheasent's Avatar
ttt
Old Apr 2, 2002 | 05:32 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Kinda sounds like the choke pulloff. It is easy to fix if you can find one. Do a search on here to find more about it, but I guarantee it is the problem if you have to keep it floored to keep it running when it is cold.
It is located on the passenger side of the carb and is hooked to the choke linkage.
Trust me on this, it is one of your problems. I had the same thing happen last year.
Later,
Jeremy
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
