Damn... now my carb is fouled and I think it is the new pump!
Old Nov 9, 2000 | 07:05 PM
Biochem's Avatar
Car: 2002 SOM z28
Now for the 3rd time this week, my car is not working. First was the bolt that help the old pump on, next was the dead battery on the way home from the shop that drilled it out, and now it appears that the carb and maybe the plugs are fouled due to the carb running too rich from the high volume pump! I am praying that a bit of carb cleaner will help get the car home, but my wife is NOT going to like this...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Nov 9, 2000 | 08:35 PM
Biochem's Avatar
Car: 2002 SOM z28
Well, I sprayed half a bottle of cleaner down the thing and it still won't fire. It tries like hell, but no go. The battery is fully charged... heck, it's only 1 day old!
Pulling a plug is not an option right now, but disconnecting the MSD box is... may try that because I am despirate!
Old Nov 9, 2000 | 11:27 PM
82z's Avatar
82z
Don't even tell me you put on a high volume pump on a street car. The mechanical fuel pumps may be set at ~7 psi but still deliver to much volume for you application resulting in overpowered needles and seats and a flooded engine. Please Please tell me that your pump is not electric w/o a regulator. You didn't specify but if it is don't get me started.............
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi
Old Nov 10, 2000 | 07:08 AM
Biochem's Avatar
Car: 2002 SOM z28
It is a mechanical street pump rated at 6psi. With the stock pump, I was running way lean. A few others run the same pump with less mods to their 350 with no problems. There is another guy (slickrock55) that may have exactly the same problem in another post on this page.
Should the line going from the pump to the carb maintain 5-6 psi when the car is not on? Due to a lack of proper fittings, I cannot hook up my fuel pressure gauge just yet, but it is very stiff when the car is off.
Old Nov 10, 2000 | 09:30 AM
Damon's Avatar
If it's the Carter 6PSI street pump then that's not your problem. What may be your problem is fuel line crud finding its way into the needle/seat assy. when you first fired it up with the new pump. All the lines between the pump and the carb got disturbed in the process and it's possible it sent crud up to the carb. If it's badly crudded up you will get fuel just spewing out of every vent in the carb as you crank the motor. DId you replace the fuel filter in the nose of the carb or replace it with a nice in-line filter in front of the carb? you didn't fire it up without a fuel filter, did you?
Fuel pressure will stay at 5-6 PSI for a minute or so after turning off the car until the tiny bleed-back holes in the fuel pump valves release the pressure.
[This message has been edited by Damon (edited November 10, 2000).]
Old Nov 10, 2000 | 12:58 PM
Biochem's Avatar
Car: 2002 SOM z28
I think you may be on to something Damon. I DO have the filter in the nose of the carb, but I also have an inline filter waiting to go on once I get some fittings. I shall toss the old filter and put the inline one on this weekend.
If that is my problem, is it the filter that is crudded up, or is there actually stuff in the carb passages? It seems to run OK this morning... maybe it passed through?
Old Nov 19, 2000 | 09:30 PM
Chrome's Avatar
Car: 92' RS Camaro
Get hotter plugs...
1985 Camaro
74' 355 Small-Block
Doublehump Heads
Holley 750DP 4160
Edelbrock Performer
BlueRacer Cam 232/232
Keith Black Pistons
700R4 w/ B&M Shift Kit
B&M Megashifter
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
