Performer RPM manifold....
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
Will I be able to clear a stock hood with the taller performer RPM manifold or will I need a regular performer intake. I've got the stock LG4 carb for now but may upgrade later. Will I have problems in the future? Thanks
I had a Performer RPM under a stock 84 hood, and a 87Iroc with a 92Z hood.
95 Corvette
Morgantini Racing heads,ported intake,Dynomax mufflers, Vortex Rammer,1.6 Roller Rockers,
Holley 52mm TB, Line lock, 4:10 gears, Nitto DRs
Collector Edition wheels
PA Plate "4U2WANT"
95 Corvette
PA Plate "4U2WANT"
You should be able to as long as you use a low profile cleaner. I have a preformer ahn my 14X4 inch cleaner touches the hood a little. A 14x3 or a open screen triangle cleaner should work fine with a RPM.
I had a Performer RPM and a edelbrock 600 and it wouldnt fit under my hood, i had to pull the heat shield material out and the carb screw Still hit the top of my hood, and actually made a little dent on the hood where the screw was pushing on the hood.
I was running a 14x3 air cleaner, which was getting NO Air
i have the Performer RPM intake and holley 650 dp, and a 14X3 drop base air cleaner fits under the stock flat hood.
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
[This message has been edited by GOLD85 (edited November 07, 2000).]
Car: 85 Z
So to run a 14x3 aircleaner with the RPM, I'll probably have to go with a drop base. Also has anybody tried the fiberglass dual snorkel from ramairbox.com? Thanks
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine fits under my hood. When I was about to install the Performer RPM 7101, it looked like it wouldn't fit, I tried anyway and it fit, no problem. I have a 14x3 dropbase air cleaner.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
Zepher
WS6 Trans Am
Mine does not even come close to letting the hood close. I don't think the hood would close w/o any air cleaner. The choke horn is even with the top of my fenders. I have the Performer RPM Vortec and Holley 3310.
You may have to scrounge around the junkyards for certain 1980's Buicks with the 3.8 V6. Some had a special low-profile cap over the carb that went to a hose that connected to a remote air cleaner box. It was the only way Buick could get the hoodline really low on cars such as the Regal.
It may not be the most free-breathing arrangement but it will help you to close your hood!
Hotrodboba400
Dec 10, 2019 07:07 PM
MikkoV
Sep 9, 2015 04:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
