Having hell with electrick choke on edelbrock carb, any suggestions?
Old Nov 30, 2000 | 09:17 AM
chris83z28's Avatar
When I start the car in the morning, it seems like the choke dosent come on at all and starting is a real chore. After I start driving, the choke kicks in and the idle bumps up to about 1700 rpm. Once the car heats up some, the choke shuts off as it should. I checked the ignition hot lead and have tried playing with the fast idle and richness some but can't seem to locate the problem. Any of you guys have the same problem?
1983 Camaro Z28
Goodwrench 350ci V8, Edelbrock TES Headers, Flowmaster Catback, MSD 6al and Blaster 2 coil, Edelbrock Performer intake, Edelbrock Performer 600cfm carb. T5, 373 rear, Eibach springs, Cervin Vega speakers, Rock. Fos. Sub, Pioneer CD,
email-chris4421@hotmail.com
"I used to be a Mustang Guy! I didn't know the power of the dark side!!"
Old Nov 30, 2000 | 11:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Before you start the car when it's cold, pop the hood, rotate the throttle arm open a little and give the fast idle cam a couple taps. If it snaps closed, the choke is sticking open. Mine did the same thing when it was new.
1984 Silver Z28, decked 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
theshackle
Sep 17, 2020 08:26 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
andy74
Sep 3, 2015 08:41 AM
86IROC112
Aug 17, 2015 02:00 PM
