Fuel Pressure Guage on Carb...
Old Nov 24, 2000 | 01:05 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
on my 82..how the hell do u hook up a fuel pressure guage? i want the info first to see if i can do it...thx
Flowmaster 80 series, Random Technologies Cat, 3" intermediate pipe, SS
Hand Made Tips, 3 1/4" out, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6A Box
Currently Working On:
T5 swap
Next to buy:
Slp dual cold air intake!
1982 z28..
350 4bbl black leather inside and black outside...no mods yet except for maybe the exhaust from my firebird
Old Nov 24, 2000 | 11:06 AM
ede's Avatar
ede
on my sons car i ran a hard line from the factory flex line to a regulator w/tee. the tee went from the regulator to the gauge and the carb. pretty simple to figure out and install.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 24, 2000 | 01:56 PM
SeanSullivan's Avatar
Mr Gasket makes an inline fitting for fuel pressure gauges as well. 3/8 hose barb on both ends and an 1/8th npt for the pressure gauge. $12.00 around here, shouldn't much more than that where you are. Most any High Perf store ought to have one.
Old Nov 26, 2000 | 11:21 AM
evil t/a's Avatar
I'm running mine from a AN fitting with a 1/8 port for it.That is a blue pump regulator.
Old Nov 26, 2000 | 04:48 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, all them answers are good but i think that the fuel pressure gauge should be inside the car where you can see it. You really want to know the fuel pressure at idle but more importantly you want to know the pressure at WOT. I bought a Stewert Warner elect. fuel pressure gauge and it works just great. Now, you never want to run a fuel line inside the car. Fire Hazard !!
-Auggie-
Old Nov 27, 2000 | 03:58 PM
Damon's Avatar
I agree with Auggie. Fuel pressure readings at idle mean exactly Jack Schitt. If you want fuel pressure readings that mean something you have to have the gague somewhere you can read it while you are driving.
If you want to mount it INSIDE the car make sure you use a fuel pressure line isolator kit (available from any speed shop, just like the guage and in-line fuel line fitting) so there is no possibility of a like leaking/coming off and spraying fuel around the inside of the car.
If all you want to do is a quick road test to see if the fuel pressure is dropping off at the top of each gear then it's perfectly accepatble to use some flexible line and duct tape the gague to the OUTSIDE of the windshield (temporarily!).
Old Nov 29, 2000 | 05:14 PM
Macgyver's Avatar
On the 79, I have an autometer FPG, and fuel isolator, the guage is in the car, with Zero fire hazard, the isolator uses fuel pressure on one side of a rubber diaphragm, to put pressure on antifreeze on the other side of the diaphragm, the pressured antifreez goes to the guage inside the car, it actaully works quite well.
Old Dec 18, 2000 | 10:30 AM
MILT's Avatar
F/P can also be seen if gauge is mounted on hood. Looks sweet too IMO...
MILT
'83 HOmaro--doesn't run
'92 Bird--burnt to a crisp
'78 T/A 400--fast, Burt Reynold's style
'83 Buick LeSabre--the Ghetto Cruiser
"Without evil there can be no good, so it must be good to be evil some time!"
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
