Kinda new here, please help.....
Old Dec 13, 2000 | 10:22 PM
PPonU4Me's Avatar
This is my first post, so bare with me. I have an '87 Iroc that I swapped the 305TPI in favor of a '92 350 bored .040over, vortech heads, performer intake and 600 edelbrock carb, mild street cam, ACCELL HEI ignition. Exhaust is stock manifolds for clearance, 2.5in Y-pipe to 3" back to Flowmaster.
With this combo, it seems like it should scoot quite nicely, but guess what. Nothing sticks out as noticeably wrong. Anyone have any suggestions. Also, I can't find a bracket to hook up throttle and kickdown for 700R-4.
Old Dec 14, 2000 | 12:46 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
Check your local Schucks/AutoZone for a product by a company named Spectre for the bracket you need. I've included a somewhat fuzzy shot for you here...
also check the tuning on your Holley for kicks.
edited.due.to.changing.pictures.in.my.pages...
Enjoy
Duffster
<marquee type="slide"> </marquee>
[This message has been edited by Duffster (edited December 25, 2000).]
Old Dec 14, 2000 | 02:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
GM Vortec heads (I assume that's what you meant) + standard Performer intake = port mismatch. Maybe even vacuum leaks.
Stock exhaust manifolds + 2.5" y-pipe + high-flowing 350 (+ stock cat? You didn't say anything about it) = very restricted flow.
How much of the HEI ignition is Accel: The entire distributor, or just the coil/module/wires, etc.? Electronic control distributor + mechanical carb (as in your Edelbrock) = no ignition advance. That's just a wild guess; not that I assumed that you used the TPI distributor - had to ask, though.
Duffster, from what I thought you had said in other posts, you lengthened the arm on the carb for the TV cable, correct?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Dec 14, 2000 | 06:04 PM
Duffster's Avatar
no...what I did was found a 'tab' that the cable connects to for the carb.
did not lengthen anything.
Old Dec 22, 2000 | 02:35 PM
82z's Avatar
82z
I had basically the same combination as you. What is your timing set at? What jets and pv do you have in the carb. The jets for my motor were pretty lean, 65 and 69 if I remember correctly. I think that your exhaust is really the problem here. Definately hit up hooker for some headers. How much tuning have you done? It makes all the diference in the world.
grngryoutmyway
Oct 18, 2016 05:48 PM
HoosierinWA
Oct 7, 2015 10:15 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
92projectcamaro
Sep 29, 2015 07:07 PM
jbates346
Sep 22, 2015 05:22 AM
