help choosing intake manifold
get an edelbrock performer intake with a holley TBI unit. a comp 262 gring or something simalar would be a good cam for you 305. some headers and new 3inch exhuast. some under drive pullies. a K&N air cleaner and a good tune up, and you would have a pretty smokin 305, oh and some better gears out back would probley help, ie. 3.42s.
have fun
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
have fun
yeah, i would agree with Gold85 about the edlebrock performer, as i have it on mine and am quite satisfied. You could go either TBI or get a non-cc carb and just modifiy that for some real performance gains. With either setup you should run an open-element aircleaner (drop base to clear the hood) Good luck
86 Camaro
LG4, Tuned Q-Jet
Edlebrock Performer Intake, Edlebrock Open Element,High Flow Cat,Dynomax Catback,B&M Megashifter, 180* TSAT, 3.42s, 800 Watt System, !EGR
86 Camaro
LG4, Tuned Q-Jet
Transmission: 4L80E/4L80E
Consider a Weiand Action + manifold instead of the Performer. An EGR version is available, and the RPM range is slightly higher than the Performer.
You can't just bolt a TBI unit on top of teh Performer (or any carb manifold). You will need some type of adapter plate to sandwich in-between. I am sure others on the board could help you as I have heard about it being done several times.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
