Choke/idle problem
Old Dec 22, 2000 | 03:50 PM
JamesParker's Avatar
Choke/idle problem
I drive an 84 Trans Am with the manual 5.0L LG4 V8 and Rochester Quadrajet carb. Here's my problem...
Symptoms:
- idle revs around 3000rpm
- choke light permanently on
- check engine light indicates error 45 - rich exhaust
- buzzing choke heater relay
The car did the first symptom a couple of times about two-three months ago, but it was solved by just leaving the car for a bit and then re-starting.
A few weeks ago the symptom returned (along with all the others) and hasn't stopped yet.
Things I've done:
- ECM diagnostic (error 45 as above)
- carb choke plate test (doesn't open - as expected)
- replaced choke thermostat (no difference)
- examined choke heater relay (looks fine - no breaks in the copper coil
With a power supply direct to the thermostat it works fine, but the relay doesn't seem to be delivering the voltage needed to heat the bimetallic strip properly.
I'm pretty new to all this but I hope the above makes sense to the experts out there. Any advice very welcome.
Thanks, and Happy Christmas!
James
James Parker
'84 Trans Am
Old Dec 23, 2000 | 08:17 PM
jrr's Avatar
jrr
I think you solved your own problem. Replace the relay. Appearances don't always work. A relay can be AFU and "look" O.K.
A buzzing relay also means that the solenoid coil either isn't getting enough juice or there's a bad short inside the relay somewhere. It has enough to close the contacts but the voltage drops and the contacts open up again. This goes off and on at a VERY rapid rate, hence the buzzing.
Old Dec 29, 2000 | 04:03 PM
spitfire350's Avatar
mine did the same thing, but only idled at 2000 and i just replaced the choke heater relay and it works like a charm. but get the relay from the j-yard!!!! GM wants like 25 dollars for the thing.
later and good luck
keep the stang's far behind u and the cops even farther
Old Jan 11, 2001 | 02:04 PM
Thank you both. After having shelled out for a new choke thermostat and an hour's labour at the garage, it was just the relay after all.
Still, at least the beast is back on the road - first drive for six weeks last night really brought a smile back to my face!
Cheers,
James
James Parker
'84 Trans Am
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
