TBI to Carb.... whats needed?
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Ok, I want to switch from my TBI setup to a Carb, what will I have to change? Also, is this going to affect anything else on the car, like my speedo, AC, or Cruise Control?
Thanks for any help,
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch.
-=-Mike
There's a tech article for converting to carb from tbi. But basically, you'll be eliminating the computer. You'll need a carb, vac distributor, either a fuel pressure regulator or fuel pump. If you leave the harness in you can still use your exsisting fuel system w/ a regulator. If you remove the harness you'll either need to wire the fuel pump to come on with the switch or install a mechanical fuel pump. I made the swap a couple of months ago. Was a two day job.
