Q-JUNK PROBLEM
Old Jan 12, 2001 | 12:28 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Q-JUNK PROBLEM
OK HERES ONE FOR ALL YOU TO LAUGH AND HELP ME WITH, OK IM EXTREMLY DESPERATRATE MY Q-JUNK HASBAD, BAD,BAD,BAD PROBS STARTING OF THE MORINING OR ANYTIME ITS COLD(THE ENGINE ANYWAY!)IT NOT A COMPCONTROLLED Q-JUNK ITS A OLDER ONE WITH A H.E.I. VAC ADvance distributor,it flods non-stop,oh yeah the float is perfect,its brand new i had a old one and set it perfect and this still happened,and when i floor it it bogs like hell,and ive tried four different size seconday rods,ive also tried smaller primary jets and rods,also three setsi have72 in front with 72 rods,and the thickest sec rods i had and it still floods and bogs helP!!!!! PLEASE!!! OH YEAH I FORGOT TO MENTION IT GETS 5 MILES PER GALLON ON THE HIGHWAY AT 60MPH ANY IDEAS ONTHIS? P.S. WHEN I GET THE MONEY A EDELBOCK 600 IS DEFINETLY LOOKING GOOD!!!!
Old Jan 12, 2001 | 10:37 PM
Bort62's Avatar
Well, a couple Of Tips.
First, Punctuation Is your friend.
The Caps Lock key is Not.
My mind is So jumbled after trying to Decipher that Visual assault of a paragraph I cant even begin to address the problem.
Any Vaccum Leaks ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 13, 2001 | 05:38 AM
merf23's Avatar
What are you using for a fuel pump?
Old Jan 13, 2001 | 11:17 AM
No vacuum leaks known of! Checked again and again and again for leaks so I'm 99% sure there are no leaks! As for the fuel pump....I'm using a brand new stock mechanical fuel pump!!
Old Jan 14, 2001 | 06:19 AM
jrr's Avatar
jrr
I have feeling that, in the middle of your frustrations, you either forgot to put the float needle back in or somehow the needle is hung up and not controlling the flow of gas into the bowl. THAT would cause non-stop flooding!
If your float IS set right and nothing's hanging up, then I'd say that the fuel pressure is too high. You may have a new stock fuel pump but is the return line blocked? The fuel pump will pump more fuel than the carb can take, so the relief valve will open and bypass that extra gas back to the tank.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
