carb and manifold
Old Jan 21, 2001 | 10:49 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
carb and manifold
i have a rochester carb and i stock manifold on a corvette 350. i was told that if i put an aftermarket carb like an eldebrock on a stock manifold it would have some vaccumm leak even with an adapter. is this true and if i replace the carb should i do the manifold to? or can i just do the carb not lose power and if i do lose power how much?
350 vette engine
aluminum heads
235/60R15 BFgoodriches
3"flowmaster exaust
20% tint
Old Jan 22, 2001 | 01:58 AM
burnoutrpm's Avatar
ok first you wont have a vacuum leak if you use the correct adapter. use the one that has a q-jet looking side anda square looking side not the four hole adapter!!! it could cause leaks! as for how much power if just changing carbs you wont lose any! in fact you'll only gain horsepower! get a holley 4150 dpr or a edlebrock 600 and you wont be dissapointed email me with any questions you might have.
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods performer rpm air gap intake (polished) and 600 edlebrock carb, comp roller cam, and way better headsa 400 defintely in the works!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
