Stall Problems
Old Apr 1, 2002 | 08:10 PM
83FBird's Avatar
Car: 1982 Trans Am
Engine: 305 V8, 4bbl
Transmission: Stock Automatic
Stall Problems
I drive a 1983 stock Firebird, with a 2.8L V6 engine. When it first starts the fast idle runs nice, but when I first kick it down, it stalls when the gas is let up. Every time I press the clutch in at a light or stop sign, it stalls. After about 10 minutes of driving, this problem goes away, and the car runs fine. Any suggestions on how to stop the problem entirely?
Old Apr 2, 2002 | 07:52 AM
82camaro's Avatar
Car: 82 camaro SC
If it runs good once it warms up, I would guess it's a choke problem. Sounds like it's too lean, richen it up a little bit and see if it helps. If you don't know how, just let us know.
Old Apr 4, 2002 | 06:25 PM
83FBird's Avatar
Car: 1982 Trans Am
your right, im not quite sure how to richen it up? any help?
Old Apr 4, 2002 | 08:25 PM
82camaro's Avatar
Car: 82 camaro SC
The choke is on the passenger side of the carb. It is round and usually has 3 screws holding int down. I should say rich / lean. Loosen the screws and turn it a little toward the rich. You may have to drill out rivets if it doesn' have screws.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
