New carb and intake
New carb and intake
I'm looking to get a new carb and intake for my 86 TA. I have a stock 305 with no mods. what the hell should i get??? im looking at either 650 or 700 cfm carb. What brand? Also what type of intake? What brand? Thanks a lot to who ever can help!!!
86Trans Am
86Trans Am
600 edlebrock(1405) part#, and a performer rpm intake of couse in no way is this smog crap legal! but, is fun!!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
600 cfm edelbrock and a performer intake would be good for you car. dont gat a performer RPM, its not necesary for your aplication
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
[This message has been edited by GOLD85 (edited February 22, 2001).]
R.I.P #3
Transmission: 4L80E/4L80E
I would say you're looking in the wrong place. In addition to the carb, you're going to need a vacuum/mechanical advance distributor. When you get it all done, the change in performance will be next to nil, and your gas mileage will likely suffer, especially if you have an automatic since your TCC will no longer lock (without a seperate switch).
Go for exhaust upgrades first. You'll notice an improvement in performance, and your mileage likely will not suffer (enjoying the right foot effect notwithstanding). Then, cam, then heads, THEN intake. Even then, keep your q-jet.
This probably isn't what you want to hear, but it's what you should listen to.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
86IROC112
Aug 17, 2015 02:00 PM
