Need help with choke on 84 Z-28!!!!!!
Old Feb 24, 2001 | 02:53 PM
IROCracer's Avatar
My friend's 84 Z has a 5.0 carbed engine, and the butterflies just hang open....I think there's some wire missin or something...casn anyone help?
If you've gotta fix it, fix it better than stock.
Old Feb 24, 2001 | 06:11 PM
scott90-50's Avatar
My 84 has the same problem. I took the carb off today and traded it in for a new one. I would like to know the answer to this to in case I still have this problem later.
1990 5.0 AOD lx
best on old combo
13.65 at 104.57
347 stroker coming
1984 camaro z-28 stock and slow
1982 mazda rx-7, 350 swap in the works.
superstangs messageboard
Old Feb 24, 2001 | 11:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If a wire was missing (i.e., the power to the thermostat), then the choke would be slow to open and probably wouldn't open all the way.
Sounds more like something isn't connected properly internally or is loose/broken. The first thing to check would be the linkage to the butterfly. Next, insure the tab on the thermostat spring is engaging the tab on the carb linkage (this will require removing the choke thermostat housing). Also possible is that the thermostat is not properly adjusted.
Has this carb been taken apart recently? The choke mechanism is a bit tricky to get together, and if something wasn't tightened properly, it may have come loose enough to no longer shut the butterfly.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Feb 25, 2001 | 09:18 AM
Biochem's Avatar
Car: 2002 SOM z28
More info needed. Did anyone mess with the choke houseing? It could be installed 90 degrees off or something. Another possibility is that the thermal spring (I don't know what else to call it) inside the choke houseing could have snapped and then it would need to be replaced. The butterfly should have a bit of "spring" to it if you try to open/close it with by hand.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
ZEEYAA
Apr 16, 2023 08:29 PM
PurelyPMD
May 5, 2016 04:57 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
lewandom
Oct 1, 2015 08:15 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
