Strange Idle....
Old Feb 24, 2001 | 10:53 PM
Yam's Avatar
Yam
Strange Idle....
My car has started to idle strangly. When I first start the car it will idle normaly but after the engine is hot the RPMs will fluctuate between 1000 and 700 (in park). Which isn't that bad just anoying but now is has started to drop down to 400. In drive it fluctuates between 700 and 400 which is nearly stalling the engine. I also noticed the other day that the AMPs were fluctating with the engine staying at about 13 when the car was at 700rpm and dropping to about 5 when it was at 400rpm but I've only seen it do this once.
Anyone have any ideas?
laters...
Yam
'89 IROC, custom 600cfm Holley carb, Street Dominator Intake, Flowtech headers, no cat, Flowmasters, no emissions (smog pump, charcoal fillter etc), remote starter solenoid, push button start, getto sound system, none leaking sunroof
Old Feb 25, 2001 | 09:19 AM
Biochem's Avatar
Car: 2002 SOM z28
Check your base timing...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Feb 25, 2001 | 09:50 AM
The ODB's Avatar
sometimes a carb acting like that is nothing more than moisture or a little dirt clogging some passage or airbleed. Run carb cleaner through the whole thing to eliminate this possibility, then continue troubleshooting.
The ignition is a good place to start your checks.
Old Feb 25, 2001 | 09:58 AM
Jester's Avatar
Hey Phil. Did you try just leaning out the idle yet?
if so, Bring a can of carb cleaner to work on monday, with the straw..I'll show you the best way to blast that out. I can take a timing gun too...give us something to do at break.
BTW..I picked up some 4" exaust pipe yesterday
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
[This message has been edited by Jester (edited February 25, 2001).]
Old Feb 25, 2001 | 01:53 PM
Yam's Avatar
Yam
I'm gonna lean it out today and see if that helps any. I would do the timing but since I gave you my timing gun we can do that tomorrow.
where did ya get the 4" from? and did you get the heads on the block yet?
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
