WTF !?Carb Popping??
Old Mar 5, 2001 | 10:08 PM
mustangs killer's Avatar
My engine got up to 250 degree's yesterday when my belt broke. I shut The engine down as soon as I noticed the temp climbing. I have a 355 with a 750 edelbrock perf. carb on top. I put a new belt on today and started it up. I let it idle for 20 min. and it was fine. Now when I rev it up the carb pops like compression is runing back though it. It only pops 3 or 4 times and then it stops.I took the vavle covers off and there is no broken spings and it seems to be working right. Does anyone know what this might be. Thanks
Old Mar 5, 2001 | 11:20 PM
FlashGTA
Guest
Posts: n/a
This is a stretch but is it possible you damaged a plug wire and it's cross-firing? Other than that, check for anything that would cause a cross-fire, possible cracked cap.
Old Mar 5, 2001 | 11:44 PM
The wires are o.k. and so is the cap but thanks for the suggeation.
Old Mar 6, 2001 | 03:34 AM
The ODB's Avatar
damaged valve maybe.
Old Mar 6, 2001 | 03:33 PM
I found the problem. burnt head gasket. Thanks
db057
Apr 28, 2019 07:45 AM
camarohelp
Sep 22, 2015 03:19 PM
Racerx974
Sep 19, 2015 10:16 AM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
