What A/F ratio should we aim for at WOT??
Old Mar 15, 2001 | 06:40 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I've got the 14.5/1 cruising range down, but what is the ratio to aim for at WOT? I've got a Edelbrock A/F guage and was just wondering if I can get a little more power by running fatter at WOT (have to swap in a secondary metering block w/ bigger jets if so I guess, since I have the un-adjustable metering plate...)
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Mar 15, 2001 | 06:57 AM
Jester's Avatar
Opinions vary, but generally 13.5-12.5:1 is what ya wanna shoot for.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Mar 15, 2001 | 11:19 PM
The ODB's Avatar
13.0:1
Old Mar 17, 2001 | 03:42 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Alright, apparently I'm running slightly lean at WOT then (if I trust the guage 100%), about all I get is an indicated 13.5:1 at WOT at best, looks closer to 14:1 to me.
About the only way to richen up WOT mixture without screwing cruising mixture w/ a 3310 is to swap out the metering plate and put in a block so I can play w/ the jets right? I think I'll look into that shortly.
The engine is a Vortec headed 350 w/ a XE262 cam, Perf RPM intake, MSD pro-billet distrib, TES headers, good exhaust, etc in case any of that should factor in to the mixture I would want to run. I figure if anything I would want to run toward the richer side of the range at WOT for this engine. Any comments?
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
[This message has been edited by Ray87Z (edited March 17, 2001).]
Old Mar 18, 2001 | 01:40 AM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
BTW, are all/most holley metering blocks interchangable? Specifically, will a secondary metering block from a 650 dblpumper work properly on my 3310? I have a 650 dbl pumper that I could pirate the block from instead of buying new stuff...
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Old Mar 18, 2001 | 04:31 AM
The ODB's Avatar
don't trust your gauge. Run as lean as you can before your trap speed starts dropping.
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Linson
Oct 1, 2015 09:50 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
