CARB OR TBI??????
Old Feb 28, 2001 | 04:33 PM
pgriffith's Avatar
CARB OR TBI??????
I have an 89 camaro with a 305 TBI, I want to put in a 350. Would this TBI be enough to power my 350? Or would it be better to put on a Carb???? What all would i need to convert to carb?
'89 RS camaro: 305 TBI, 700R4. Upgrades: K&N Air filter, Dynomax Superflow cat, Stage 2 Jet performance chip. New paint job.
Old Feb 28, 2001 | 10:22 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
You'll get more power from the carb!! My friend did the TBI swap and I just so happen to have a small list of the items you need for the swap!
* A mechanical fuel pump
* fuel line (about 10ft)
* A carb (obvious)
* a carb intake (obvious! Also, edelbrock air gap intake will NOT fit under a STOCK camaro/firebird hood)
* a non-computerized distributor (HEI vacuum advance is what he uses)
* Vacuum Line
* A throttle cable (from an 82-84 camaro/firebird with a carb....you can pick one up at a parts store)
* Throttle cable stud (will come with an edelbrock electric choke carb but not the edelbrock manual choke carbs...still trying to figure out why)
* Kickdown cable stud (again, will come with an edelbrock electric choke carb but not the edelbrock manual choke carbs)
* Carb studs (once again, will come with the electric choke carbs, not the manual choke ones)
* Mechanical Oil Pressure Guage (you have to disconnect the electric guage to disable the intank fuel pump that you have....if you don't disable it your intank pump will still kick on....NOT GOOD)
* Throttle cable bracket
* Air Cleaner (obvious....K&N is the #1 choice)
* Return spring and bracket
I think that pretty much covers the needed items for the TBI to carb swap!!
Need to know more....email my buddy that's actually done the swap at burnoutrpm@hotmail.com
or email me at pjstar@mo-net.com
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Hedman Shorty Headers, Stock casting pocket ported heads (2.02/1.60 - 65cc), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Mar 20, 2001 | 08:12 PM
Blue89RS's Avatar
I recently did a similiar swap(305 to a 350) i would stay with the injection. Everything you have right now will work with the new motor. That alone will save big $$$$$, and you will do better on gas.If it was mine i would leave it alone, not goin to gain that much power anyway without big mods.
Old Mar 21, 2001 | 04:55 PM
Blucamaro's Avatar
I too have done the 305-350 swap in my 89 RS,I did keep the Tbi and it's really not that bad,although I do plan on getting a carb and intake someday.In other words if your happy with the results of the Tbi,then just keep it.
Old Mar 21, 2001 | 08:53 PM
The ODB's Avatar
Carb
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
