Having terrible time getting holley 750 DP to idle and part throttle decent
Old Mar 31, 2001 | 04:59 PM
Wayquick4u's Avatar
My holley 750 double pumper i just put on my 383 stroker doesnt like to idle real well, and almost always dies when i put it in gear, ive tried everything. The floats look right, idle mixture screws look right. I dont think it has a vacuum leak.
Old Apr 1, 2001 | 01:00 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Try opening up the secondaries just a bit. There is a screw on passenger side where you can open secondaries . This allows you to have to open primaries less. The more you open them the more they expose the transfer slots and then u loose the ability to adjust your carb with your mixture screws.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,kickdown kit and tranny oil cooler. Will install 3.73's later on and might go with a more aggresive cam.
Old Apr 1, 2001 | 09:21 AM
Damon's Avatar
That's a good suggestion, above. I assume the thing is running rich as all-get-out, right?
Old Apr 1, 2001 | 01:10 PM
82camaro's Avatar
Car: 82 camaro SC
What rpm do you idle it at. You might need to idle it up a little. If you don't have enough vacuum at idle the power valve could be open. Or it could be stuck or blown/leaking. If you can lean it out until it stalls at idle, you shouldn't need to mess with the secondaries.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 1, 2001 | 05:18 PM
kevin v's Avatar
how much duration @.050 does your cam have? and is the carb box stock, w/2 or 4 corner idle? where are you trying to idle the engine?
Old Apr 1, 2001 | 08:19 PM
Wayquick4u's Avatar
Im idling the engine at a 1000. the cam is mild street/strip. When i pull it in gear it drops to about 800. I closed the secondaries up and now the car stays running in gear
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
