wiring a quadrajet
wiring a quadrajet
I have a LG4 85 iroc and i had to buy a knew carb for it. I got the standard quadrjet and i need help rewiring it to everything i used tape marking most of the stuff but there is still some questions i still have. Does anyone know a site about how to wire up a quadrajet?
actual wires or vac lines?
Should be 3 wires choke, tps and imc they fit where there supposed to. vac lines should be 3 also bottem big one goes to the vale cover,
small one on front goes to the air cleaner and small on on back goes to a 3 line split into one. I dont know how much you took off so cant be much more helpfull
but thier should be a vac diagram on the fan shroud or front inside bottem of hood.
but thier should be a vac diagram on the fan shroud or front inside bottem of hood. Thread
colton_carlson
Mar 8, 2019 12:21 PM
