AFPR layout...
AFPR layout...
I'm converting from TPI 2 Carburetor and I'm gonna keep the intank pump, does any1 have a diagram or know the layout 4 usnig an AFPR? I know how the layout goes 4 TPI but not on a carb. I've seen pics in magazines with AFPR's on carbed engines but there was no return line in any of them. Just 1 feed line 2 the regulator and 2 feed lines from the regulator 2 the carb. I don't want to burn out the pump. Thanks.
Transmission: 4L80E/4L80E
Well, no responses after 9 days. So...
Use a 3-port regulator with return. That's your best bet with the factory in-tank pump.
Not sure what you mean by "1 feed line 2 the regulator and 2 feed lines from the regulator 2 the carb". Not sure if you mis-typed, or you really meant "...two feed lines from the regulator to the carb" (it would help if you used "to" for direction and "two" or "2" for quantity). But, the two feed lines you've seen from the regulator to the carb were probably for a dual-feed Holley (one regulated line each to the front and rear fuel bowls). Or, they ran the return line as close as possible to the carb to keep the fuel as cool as possible going into the carb.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited April 23, 2001).]
2012sergen11
Oct 13, 2015 07:38 PM
