Does anybody know where to find a fuel filter for a CC QuadraJet?
Old Apr 23, 2001 | 10:46 PM
Golden80's Avatar
Can I find one at my local parts store or do I need to order one online?
Thanks,
Matt
Old Apr 23, 2001 | 10:54 PM
SUPER-SPORT-CHEVY's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Golden80:
Thanks,
Matt
</font>
Same filter as a non cc qjet you just need to find out what size it is and it should be avalible at a local auto parts store for 2/3 bucks. They are very common filter. GL!
SSC
Old Apr 24, 2001 | 12:58 PM
82camaro's Avatar
Car: 82 camaro SC
wal-mart
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 24, 2001 | 03:42 PM
Aaron87SC's Avatar
They're everywhere.
[This message has been edited by Aaron87SC (edited April 24, 2001).]
Old Apr 25, 2001 | 07:42 AM
350HOZ28's Avatar
For the money you spend, I would ditch the CC Q-jet inlet filter altogether and put in an inline aftermarket filter that flows and filters better. The stock CC Q-jet fuel filter is somewhat restrictive...especially since it is right as the fuel enters the carb. AN aftermarket one is fairly cheap and will help performance some. But as mentioned above...you can get stock ones about anywhere.
Formerly known as 1984L69Z28
1984 Z28 - L69 optioned, 350HO w/ Trick Flow Heads, Drop Forged Lunati Crank, Crane Cam and 1.5 Roller Rockers, Stock Z28 Intake Manifold, Highly Tweaked Rochester Carb(700cfm), K&N Filter, ThermoMaster Chip w/ 160 Stat, Comp Headers, 3" Stainless Dual Exhaust w/ no Cat & Dynoflow Muffler, 4 wheel disc brakes, etc....
God bless us father, son, and holy ghost....whoever goes the fastest wins the most!!
Old Apr 25, 2001 | 09:59 AM
Golden80's Avatar
So if I use the inline filter should I just pull the old one out and put the screws back in it with no filter? Also...where at should I put the inline filter?
Matt
Old Apr 26, 2001 | 01:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Screws?
The stock filter is behind the inlet adapter fitting to which the fuel line mounts to the carb. Take off the fuel line (5/8" wrench on the line nut with a 1" open-end wrench keeping the adapter from turning), then remove the adapter. The filter will be behind the adapter with a spring behind the filter.
The only advantage of having the carb filter if you have an in-line filter is the anti-drainback check valve. However, I'm running my in-carb filter with the check valve removed with no problems.
Unfortunately, there isn't a good place to mount that fat in-line filter within the tight places under our hoods. Just replace the in-carb filter - you'll be fine. In the wide-open spaces of my '57 engine compartment, I run an in-line just off the fuel pump, no in-carb filter.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
