Classified Ads Feedback Board Use this board to discuss your Classifieds transactions, buyers, and sellers. Do Not post ads here, they will be deleted on sight and without notice.
V6 injector problem. I need advice.
Old Jun 19, 2003 | 06:17 AM
warlord6six6's Avatar
I have an 1987 camaro with a 2.8L. I replaced the head gaskets and re-assembled. It is a pain to get started now and pops through the throttle body. I pulled a compression test. All cylinders came back the same. 120 psi. I pulled a vacuum test and it slowly drops to 2 from about 10. which suggests I have a vac leak. but, I can't find it. Can't even hear it. either way I don't think a vac leak would cause a backfire through the throttle body. So just to be on the safe side I want to check the injestor loom to be sure all the harnesses are on the right injectors. #1 and #6 can't be screwed up. the length of the wires keeps this from happening. so I either crossed #3 & #5 or I crossed #2 & #4. Just wanted to know if anyone out there had a trick or method to finding out how you can tell which clip goes to it's proper injector.
Please contact me at warlord6six6@comcast.net
Thanx again peeps.
Old Jun 21, 2003 | 12:19 PM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
A vacuum leak will cause a nasty back fire through the plenum. 10 vac is pitifully low. Hows your vavle lash? is it set correctly? i try takeing the big vaccum line off where it goes into the IAC motor. ans plug that line. that saved me *** in a simalar situation. then get some carb cleaner with a straw and squirt it all along every seal that could be a potential vaccume leak. squirt a small amount to avoid overspray. if the engine suddenly gains rpm, you've found a vacuum leak. but a vacuum leak will definatly cause some serous back firing through the throttle body
gta892000
Aug 11, 2019 11:16 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
383cam
Sep 9, 2015 06:01 AM
mrdevontay
Sep 2, 2015 08:04 PM
