glass window
Old Jan 29, 2004 | 01:47 PM
1986sc's Avatar
Car: 92 Z28 92 RS Vert
Engine: 350 TPI 305 TBI
Transmission: 700R4 Auto (2x)
glass window
hey guys. im replacing my top. i hate the plastic window. it s visibility sux. also, the plastic windows dont usually last long because they are crimped and they tear. i plan on gettting the stayfast top with glass window. how does the glass window fold into the torneau cover??? the plastic one, you have to fold. is the glass window worth getting for my top ? thanks in advance.
also, MODS, i hope you plan to keep this convertible board. It makes us vert guys feel more aquainted.
Old Jan 29, 2004 | 02:54 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
lika Dis....
Old Jan 29, 2004 | 06:34 PM
1986sc's Avatar
cool zedder! did the defrost lines come with the window or did u put it on ? also, is that top aftermarket? if so, where did you get it from ? how much ?
Old Jan 29, 2004 | 07:43 PM
Engine: LB9
Well, thats not my car so I can't answer any of those questions. Someone posted a link to the website that I got those pics from on a post within this board.I too want a top with a glass window a la 4th gen. My buddy has a '95 z28 rag and the only problem is that the window is very small and outward visibility is limited with it.
Old Jan 30, 2004 | 02:48 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I got mine from topsonline.com and I must say with a good installation it was an excellent move. I didn't put a defroster on it, but I tinted it and it looks great. Compared to a mint plastic one of course you have less visiblity, but it still does the job and after folding it down a couple of times you get how to do it.
Old Jan 30, 2004 | 07:07 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
I looked into getting a glass window when I got my top. I forget the extra cost but it was considerable but not so much that I would not have done it If I weren't already spending so much money on other things for the car at the same time.
Your post asked about dealing with the glass when the top goes down. My understanding is that the glass unzips from the top and lays in the bottom of the topwell. The top is then folded back on top of it.
Old Jan 30, 2004 | 07:25 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The glass in the picture above doesent unzip. Its much smaller than the rear stock plastic window, which lets it fold down with the top. You just have to be careful when doing it.
Old Feb 1, 2004 | 12:07 AM
92rsconvertable's Avatar
Hey that purple camaro is my car.. and thank you for using that pic i lost it and was trying to find it around here and i finally did.. I definatly recomend the glass top easier to keep clean dont have to wory about it turning yellow or anything.. you can also hook up the defroster to it.. i still havnt done it b/c im away at school right now. but the top works great no leaks or anythings. after i first installed it i was a little shakey with the way it went down but it works fine no problems at all... The glass also keeps the car a bit warmer in the winter too.
Old Feb 1, 2004 | 10:55 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
where did you get the top from becuase i had mine folded down the other day and it was cold as hell so when i lifted it up it ripped so now i have to replace it plus i cant see out of it anyway and im looking to replace it with glass
Old Feb 2, 2004 | 04:11 PM
i got mine at topsonline.com the stayfast canvas with glass window. it looks like the same glass window from the newer camaro convertible and corvette convertables. $399 and then you just have to get it installed. Total costed me about 700
Old Jun 2, 2011 | 12:41 AM
blakecharles's Avatar
Re: glass window
Sorry to bring this old thread back, but nobody asked about the elephant standing in the room... never mind the top (there are many vendors that sale them... almost all are resellers for EZ)..
Where in the world did you get the defroster???
Old Jun 17, 2011 | 11:04 AM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Re: glass window
x2
Old Jun 18, 2011 | 09:35 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: glass window
Lots of places (like this . . . http://www.frostfighter.com/prt2600.htm) sell kits for any size window. A friend of mine here in the great white north put one in. The biggest challenge was running the wires for a folding roof. Be sure to avoid any pinch points. He ran the wires in the thinnest black wire loom that fit around the wires. This made them look factory and provides some limited protection. Then the loom was secured along the roof's frame using stratgically place black zip-ties and black screw clamps (using existing factory screw locations) and run down to the where the main hinge meets the car. From there the wires meet up with some factory wires and continued down behind the trim, under the carpet, along the door sill and up behind the dash. Where you put the switch is up to you. Maybe behind a blank factory switch cover, etc. He hooked it up to an ignition activated power source to prevent a dead battery should he forget it was turned on.
Old Jun 18, 2011 | 09:41 AM
Axle/Gears: 3.08
Re: glass window
PS; Although the wires can be applied to the inside of the glass anytime, if you're putting on a new roof, it's a little easier before installing the roof.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
