Deck lid adjustments
Old Mar 3, 2004 | 08:26 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Is the deck lid adjudtable side to side? My lid need to come over a bit and I can't seem to get it right with the bolts that attach the lid to the hinge. Are the hinges adjustable where they bolt to the body?
Old Mar 5, 2004 | 07:44 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Does anyone know? Every vert I have seen has the deck lid off one way or another, surely some one has adressed this problem.
Old Mar 5, 2004 | 07:54 AM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
gmgod
I don't know the answer to your question right off... I know when I had my car painted that the trunk lid was removed and rust damage was repaired. there was a problem with alignment of the deck prior to the painting and the shop adjusted it out. How that was done I don't know and haven't looked but the next time I get a chance I will try to figure it out and let you know...
I'm surprised that no one else has responded to this as I am sure it's been an issue for somebody else at some time...
Speedy
Old Mar 26, 2004 | 01:54 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Without seeing pics or looking at the lid mounting arms, it will be difficult to diagnose. If everything is bolted down tight, just loosen one side and use a metal shim. Then tighten it back down. I know it sounds like a ******* solution, but it will move the lid over to center.
Linson
Oct 24, 2025 02:00 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
