spoiler help
Old Jan 14, 2005 | 12:18 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
spoiler help
my spoiler broke off of my car just the other day. anyways can someone help now how can fix this here is a link
https://www.thirdgen.org/techbb2/sho...hreadid=274605
if anybody has a used spoiler to i would be very intrested in buying it
thanks,bryan
Old Jan 16, 2005 | 07:03 PM
bxrman's Avatar
Car: 1988 IROC-Z Convertible
Engine: 305 TPI, LB9
The link you referenced is exactly how you should reapir it. I had three out of four of the plastic posts break on my spoiler when I fixed it. I used an epoxy specially designed for plastic, and it worked great.
Old Jan 16, 2005 | 08:12 PM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
I used two part epoxy also. Used the grinder to reestablish clean surfaces AFTER I lined up the correct posts in the correct positions. Seems to work just fine. The addition of two sided tape helps also.
Old Jan 17, 2005 | 12:17 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
the problem is two of the other plastic peaces broke in half and are gone on the ground somewhere.
Old Jan 17, 2005 | 04:03 PM
Check the inside of your trunk carefully. They should be in there somewhere. If not, check with the local wrecking yard. Lastly, You may have to fabricate something yourself. Try a carriage head bolt, grind the top somewhat flat and line it up and epoxy it. To get the proper linement, First epoxy the ones you already have, let them harden. I would then put the carriage bolts into the trunk lid with washers and nuts holding them in place. I would apply a liberal amount of epxoy to the tops of the bolts and set the spoiler on top of them using the studs you have already epoxied to line it up. Hold it there until the epoxy hardens, take the entire thing off and then re-epoxy the carriage bolts to make sure you have good coverage.
Two part epoxy is easy to use. Get the one with two syringes hooked together. Apply it to a smooth surface and mix the hardener and resin together very well. It doesn't take all that long to dry.
Old Jan 17, 2005 | 11:43 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
thanks for all the help everyone. i decided to have my dads friend help me fabricate some aluminum studs in all four places. i found that i had two of the plastic pieces that broke off the spoiler,but i will keep those on the side. this aluminum shoudn't break now. i will take pics of what it looks like. it should be done in week or so. thanks again, bryan
sp8ty
South East Region
Sep 24, 2018 03:55 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
F-body-fan
Nov 4, 2015 06:13 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
skip91
Sep 22, 2015 10:25 AM
