Question on vert seatbelts???
Old Jul 28, 2005 | 08:56 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Could I take the seatbelts from my vert and a set from a coupe or t-top to make a better looking set to go in my vert? My problem is that the ones in my 87 are light saddle (tan) and are faded really bad and I wanted to take a set of black ones from a t-top or coupe to make them look almost new again. not sure if it can be done anyone know anything on this matter also if so anyone have any good looking black seat belts? LMK Thanks
Old Jul 29, 2005 | 03:07 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
id also like to know about this.....
Old Jul 29, 2005 | 05:11 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
I believe it can be done with the front seatbelts, but the rears have a notch cut in the male end of the buckle for the convertible shoulder belt, which is different than the coupes. I'm sure Lon can provide more insight to this... Lon?
Old Jul 29, 2005 | 06:13 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I know they have a different part number than a coupes, but I've never investigated what makes them different. As Randy mentions, the rear belts are different because of both length and the notch for the shoulder belt (if yours has a detachable shoulder belt provision).
Lon
Old Jul 29, 2005 | 06:37 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
John's is an '87. It doesn't have rear shoulder belts. My rear belts on my '87 coupe and '87 convertible are identical in appearance. Note: Rear shoulder belts were added in '89.
Old Jul 29, 2005 | 07:09 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
If ASC re-used the stock belts, the question is how did they get the the upper guide on the belt? I imagine they have a way, it's just not user-friendly.
That's one of the few reason's I'm going to a 4-point harness instead of 4th gen belts. No way of getting the guide on without cutting the guide (something I don't think is safe to do)..
Kevin D.
Old Jul 29, 2005 | 08:33 PM
lonsal's Avatar
The guide is split and comes off of the seatbelt easily. There are two pieces. Both have a split in them to allow you to remove them from the shoulder belt. The split on each piece isn't visible until you disassemble it.
Lon
Old Jul 29, 2005 | 09:35 PM
shr00m's Avatar
Very clever.. A little bit of bending by the bolt hole and it will come apart. Figures as ASC reused every bit they could.
Kevin D.
Old Jul 29, 2005 | 10:55 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I'd love new belts... same exact situation with faded, frayed (not badly) original belts in brown
Side note... shopping leather seats tomorrow (shr00m). New belts would be timely.
Old Aug 2, 2005 | 06:14 PM
duly noted.
Old Aug 5, 2005 | 05:18 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
I got lucky and found a BRAND NEW set of black front vert belts on Ebay.... they have the bolt and retainer already installed..... Cost a fortune too....
Old Aug 7, 2005 | 08:57 PM
Cadillac's Avatar
911rsq, "PerryPam" by chance?
Old Aug 12, 2005 | 03:28 AM
911rsq's Avatar
Transmission: yes
Nope... I've bought a LOT of stuff thru PerryPam tho....great vendor.
I got the belts from somone else on there. i will have to look it up. They are sitting her next to me on my desk for safe keeping until the vert is ready for them. They are BRAND NEW. they look awesome.....
Now all I need are some NOS black rears to go with it....
Old Aug 23, 2005 | 07:02 AM
jstoltz's Avatar
so how would the fronts be done? to rewind them with the black ones? do you need to replace any springs or anything never rebuilt seat belts before so I have no idea.
Old Aug 23, 2005 | 06:50 PM
shr00m's Avatar
As far as I've seen, you don't... You find a new/used set. I'm not saying you can't, but I've never seen it documented at least.
Kevin D.
Old Aug 25, 2005 | 12:37 PM
deacon17's Avatar
I have replaced the entire interior in my '88 Iroc vert and took it from faded gray to black. After going through all the crap with the belts, I would advise you to find a good upholstry shop and ask if they can replace the webbing on your belts with new webbing in whatever color you want. They should be able to match it in terms of the belt material and stitching. Try www.ssnake-oyl.com but realize that most shops should be able to do it. At least that's what a couple of shops told me in my search. I haven't had it done yet (found an old set that I'll eventually switch out) but will at some point. If you get lucky like 911rsq, that's great, but it generally takes a lot of time and money to get what you want that way. Having a shop do it might prove a good alternative.
Old Aug 30, 2005 | 02:19 AM
911rsq's Avatar
Transmission: yes
Does anyone know of someone with a set of black rear belts? I am willing to pay good $$$ for a set. It would have to be NOS.
I am a long way off from bolting belts in, so even in the future, keep me in mind....
I was just lucky to be in the right place at the right time is all.....
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Gumby
Members Camaros
Aug 21, 2015 12:50 PM
redmaroz
Aug 16, 2015 11:40 PM
