4th gen seatbelts
Old Oct 19, 2006 | 06:10 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
4th gen seatbelts
Will the ones out of a 4th gen vert work in a 3rd gen vert? My drivers one is stuck. And I upgraded to the 4th gen ones in my IROC t-top car, and loved them. I was just wondering if the same will work on the vert. Thanks in advance! Adam :-)
Old Oct 21, 2006 | 10:52 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
I am interested in this too so hopefully someone has an answer. mine is an 87 so no shoulder belts in back.
Old Oct 22, 2006 | 01:46 PM
So no one has any info about this?
Old Oct 25, 2006 | 08:11 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You might try a dealer, according to my Parts & Illustration catalog the part numbers: BELTS
Black RH P 12500230
Black LH D 12500231
Old Oct 25, 2006 | 05:42 PM
jstoltz's Avatar
only one is still available so if the 4th gen vert seatbelts would work I would rather do that anyway. I might get a set and try it sometime to see for sure. rears will be my problem not having shoulder belts.
Old Oct 26, 2006 | 08:09 AM
okfoz's Avatar
What is truely interesting is the Illustration catalog shows both RH and LH with the same part number, but the Parts catalog shows a different part number. I suspect that you would need a RH and a LH as the plastic mounting on the floorboard is different for each side...
Old Oct 26, 2006 | 08:11 AM
jstoltz's Avatar
I think it is for just the retractor it doesn't list a color choice anywhere.
Old Oct 27, 2006 | 07:44 AM
okfoz's Avatar
THey had different part numbers for Gray and beechwood I did not post those though.
JOhn
Old Oct 27, 2006 | 08:00 AM
jstoltz's Avatar
where did you find the part numbers?
Old Oct 30, 2006 | 03:01 PM
okfoz's Avatar
My IPC (Illustrated Parts catalog) and Part number catalogs... for Pontiac Firebirds, I have the IPC on Microfiche for the camaro too.
John
Old Oct 30, 2006 | 03:15 PM
jstoltz's Avatar
where did you get the IPC and can I get one for Camaro's?
Old Oct 30, 2006 | 08:04 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
okfoz and microfiche
damn dude....Im 31 and still remember days of doing library research for highschool papers using the dewy decimel system and microfiche. You go way back. That rules
The only microfiche reader at the public library nowadays is probably in the most remote corner of the basement, right next to the 'big-as-a-house' xerox machine.
Old Oct 31, 2006 | 08:15 AM
okfoz's Avatar
I still use a microfiche reader quite often. Heck I ahve one sitting right behind me as I speak, we even have a Fiche Printer, not sure if it works though...
JOhn
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
