Better pics of the Vert model
Car: 1992 Firebird
Engine: 305 TBI
OK, here are a few better pics of the 92 Vert. I have also included 2 others, although not verts, they are 3rd gens.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
looks good i used to be into models pretty hardcore. put a black wash on the door lines and and anywhere else that could use it like between the bumpers louvers etc. it will make them look a little more realistic
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
nevermind read other post.
models look good. keep up good work!
Car: 87 GTA
Car: 1992 Firebird
Engine: 305 TBI
That red you see is the color of the plastic before it was painted. It took me a minute to actually find it because it can't really be seen on the actual model. The model has a gap and the red showing in the fenderwell is the outside of the interior shell, which you really can't see unless you hold it at a weird angle. The little red showing on the grill is where the paint did not fill in all the cracks during spraying. If you put too much metallic paint (plain gloss is easier) on, it runs bad, so I do it in light coats...........good catch. As I said in an earlier post, they (almost) never come out perfect. One glitch (bad) that you did not mention is the windsheild surround on the vert. The 1st thing I did when making the vert was cut off the roof and t-tops. While doing that (the very 1st time I touched it) the skinny plastic broke in 2 places when I was cutting off the t-top. Talk about pissed!! So, anyway I had to try and put the 2 pieces back together and make the windsheild surround. It came out ok, except upon close inspection (these closeups). It is either that or trash half the models you do. (I have trashed a few) Anyway, my models are usually viewed on my display shelf and are 5 footers...............haha
(Answer to Purplehaze)That is an excellent idea that I have never tried. A long time ago I had tried painting in those little doorlines, etc. but of course could never get right. Thanks!!
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Linson
Sep 21, 2015 01:08 PM
