Removing the bottom ground effects..
Old Apr 22, 2007 | 09:13 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
On a vert how do you guys remove the 11mm speed nut to take off the ground effect. It seems that my fore arm is a bit to big to reach down there and get a open ended wrench on it.
Thanks!
Old Apr 23, 2007 | 08:12 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: Removing the bottom ground effects..
Look for a rubber plug in the factory bracing inside the car. That is covering the access hole for the zip nut holding the rear of the gfx in place
Wish I wouldn't know that when you painted my car! LOL
Old Apr 23, 2007 | 10:27 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Ahhhh ok.. Too bad the one that I am working on doesnt have that. Damn 88's but it has all the 87 peices.. Go figure.
Old Apr 23, 2007 | 10:56 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Try following the advice in this thread
http://63.99.108.154/ubb/ultimatebb....c;f=1;t=001485
I don't think I translated all the pertinent info
Old Apr 23, 2007 | 12:14 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Yeha that is for non verts. Go look at the pic's of your car and you'll see that there is a frame rail there. Right next to where the top's frame bolts down to, there is a like 2"x4" hole there to acess that speed nut.. Like I said my forearm is a bit to big to fit down there.
I think that I am just going to drill a 5/8ths hole on ither side just for the ease of removal if I ever need to again.
Old Apr 24, 2007 | 07:53 AM
dst80944's Avatar
I also drilled a hole.
Old Apr 24, 2007 | 02:50 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Thats exactly what I did and worked great!
Will do again A++++++++++++++++++++++++++++++++AAAA++++AAA+++++++++++++++++++++++++++++++++++++++++++++
Frozer!!!
Jan 19, 2024 04:55 PM
ktthecarguy
Jul 5, 2020 11:46 AM
Glowsock
Aug 26, 2015 12:28 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
