Tonneau cover trim
Old Jan 25, 2008 | 07:49 PM
tweeker's Avatar
Car: rs convertible,06 dmax,07 tahoeltz
Engine: l03
Axle/Gears: 3:42 auburn posi unit
Tonneau cover trim
Anyone ever removed the tonneau trim from the metal surface I know its glued on but will I murder it if I remove it?
Old Jan 26, 2008 | 11:57 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Re: Tonneau cover trim
No, just find a loose spot and work your way across. Mine was a zig-zag pattern of glue and easily popped from one zig to the next zag.
Kevin D.
Old Jan 26, 2008 | 01:53 PM
tweeker's Avatar
Engine: l03
There was A nice post I found that had some good pix where someone had removed it Im gonna pull it of as soon as I find a nice black piece of black vinyl to replace it with
Old Jan 26, 2008 | 04:30 PM
tweeker's Avatar
Engine: l03
I got it off pretty easily now to find a thin rubber/vinyl to replace the cover on it
Old Jan 27, 2008 | 02:03 PM
Scooby Doo's Avatar
Car: 92 Trans Am Convertible
Engine: 5.0L
Sounds good, post so pictures of the process and end results.
Might I recommend Marine grade Vinyl, I used it once on a older convertible I used to have an it held up well.
Old Jan 31, 2008 | 06:00 PM
tweeker's Avatar
Engine: l03
Well I didn't take any pix because it was sooooo easy and I couldn't find the camera the tonneau trim came off with a easy tug(be easy with it will crack)I normally get fabic from a boat upholstry place he found the exact fabric to replace it with then I got some trim glue 3M spray adhesive and laid it on like a highschool prom queen I used structural bathroom glue the guy at the boat place reccommended it.Then I stuck in on,I also laid some wood blocks ontop of it with some weight to cure looks like it came from the factory
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
codeysabatini
Sep 20, 2015 11:36 AM
355tpipickup
Sep 13, 2015 11:35 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
