Re-glue at bow 5 without replacement question
Old Apr 5, 2008 | 03:16 PM
Turbo Lover's Avatar
The rear glued edge at bow 5 has come loose on my 89. I want to glue it back down without removing the whole top (obviously). The top is very tight and doesn't want to stretch over bow 5 now. Probably the reason it has come apart. If I raise the back up to hopefully get some slack it doesn't help. Is there another part of the top, like a certain bow or rivet, that if loosened or removed will add the slack I need to get this back over the bow and glued down? I have never had one of these apart and I know they are somewhat counter-intuitive. Loosen something that should make it looser actually makes it tighter type of thing. The design factor in some of these tops is just amazing.
thx
craig
Old Apr 11, 2008 | 08:31 AM
Re: Re-glue at bow 5 without replacement question
Update. I picked up some glue at a local interior shop instead of using the 3M. Much better IMO. I got the top over the frame. I had to play tug of war to get it "stretched" over the bow for a test fit. Took it back off and cleaned/reglued. I am surprised how well the adhesive worked. Top is a little wrinkled but it was half off for the last 2 years. No big deal. Glad it's glued.
1992 Trans Am
May 10, 2023 07:19 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
