Convertible top fit question (Appreciate your help)
Old Aug 26, 2008 | 05:41 PM
67tothefuture's Avatar
Car: 1991 Z28 Convertible
Engine: 305 tpi
Transmission: 700 r4 Auto
Looking at aa 1988 iroc vert. Nice condition. Newer top. Question. Not real knowledgable about verts. When bringing the top up, it locks in fine front and back, however on the side at the back of where the door and window meet the top and rear quarter the top does not connect down anywhere on either side. It flares up a bit. So, if it were to rain it would obviously leak. Is this normal, or should this arer of the top be latching down somewhere. Any help would be appreciated, I'm deciding if this vert is worth buying. No sure if this is normal or easily fixable? Thanks!
Old Aug 26, 2008 | 06:12 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: Convertible top fit question (Appreciate your help)
The top only latches down in one place, in the very middle on the tonneu cover. There is a pin that goes into a hole and locks into place. Other than that, the only thing between the top and the tonneu cover is a piece of weatherstripping. And a lot of times the top will pull away from the frame along the edges and curl up like what you described. This can be repaired with some strong adhesive if you have the time and patience to deal with it yourself, or an upholstery shop would be able to repair it rather quickly. Basically what has happened is the adhesive just gave way and the top is no longer stuck to the frame in that area. I hope this helps.
Old Aug 26, 2008 | 08:26 PM
Engine: 305 tpi
That answers my question, thanks so much! This is a nice board, alot of knowledge about the camaro!
Old Aug 26, 2008 | 08:57 PM
BlueZee28's Avatar
No problem. Let me know if you have any other questions.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
