Camaro and Firebird top frames interchangable
Old Apr 27, 2009 | 03:23 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
The top frame on my '91 RS has a bent component which doesn't allow the driver side window to close properly. If I found a top frame from a '91 or '92 Firebird, would it match the Camaro frame, or would it only fit Firebirds?
Old Apr 27, 2009 | 03:47 PM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
Re: Camaro and Firebird top frames interchangable
same frame as long as it in the same year -89 90 91 92 same only differents is the 90-92 hand a headliner inside car
Old Apr 28, 2009 | 11:57 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
85-88 are type 1
89 Type 2 (no headliner)
90 - 92 Type 2 (headliner)
Actually the most notable difference is the 88 & prior were slightly narrower... AND they used a different clamping mechanism, not sure the difference with the clamp honestly.
John
Old May 11, 2009 | 01:49 AM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
early cars had a "threaded pin" for lack of better description, that screwed into a hole with pins protruding in to it, where as the later had a cam that was rotated onto a hardened plate. I have both mechanisms "88 daily driver has pins and 92 parts car has the cam system. I will try to get pictures posted, incidentally my '88 has a lot of rust in the drip rail over the windshield, so I will be transplanting the '92 upper windshield frame (super clean) onto my "88. when I get started I'll start a thread to track progress. I will split it at the factory seams
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
