Tonneau release will not work
Old Apr 25, 2009 | 11:09 PM
robstout3's Avatar
I have a 1992 rs convertible ant he tonneau release switch will not work. There is no clicking at all when i hit the switch. I tried grounding the switch but nothing happened. I do not have a hatch pull down. I pulled the trim off in the back and found a loose plug with 2 wires on it 1 black and the other red. There is 12v at one terminal and the other terminal is a ground. If i jump the 2 terminals I can hear the poppers clicking and there is a relay back there just almost whines as long as i have the terminals jumped. Any help would be greatly appreciated. thnx rob
Old May 1, 2009 | 12:18 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Tonneau release will not work
"I do not have a hatch pull down." BINGO! Fix the hatch pull-down unit and you fix the problem with the tonneau switch. There is a safety feature that ties in the pull-down unit with the tonneau switch. If the hatch (or trunk in your case) is open the tonneau won't release. It is to prevent the tonneau from being opened if the trunk is open.
Lon
Old May 1, 2009 | 08:57 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
the 92 model 'verts didn't get a hatch pulldown motor. They just had a latch mechanism
The safety switch is still there though, and the relay has to verify that the trunk is closed before it allows the tonneau to release
-jason
Old May 1, 2009 | 11:36 AM
lonsal's Avatar
Correct. Sorry I was in a hurry and didn't see the '92. From his description of the wiring I thought it was an earlier 91. Fix the switch and your tonneau will release.
Lon
Old May 1, 2009 | 12:30 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Guys, i have a question. I have a 1988 and the switch works but only one solenoid clicks and releases. The other side i have to release with the cable. I'm thinking the solenoid may be bad. If correct what type of shop would i send it to for repair?.....Or it could be something else entirely....
Old May 1, 2009 | 12:44 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
make sure the wire that leads from the safety switch in the trunk, to the solenoid is actually connected.
On my 88, the wire for the passenger side solenoid/popper had fallen out and was laying behind the panel
-jason
Old May 1, 2009 | 12:46 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Thanks Jason...I will check that.
Old May 2, 2009 | 02:25 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Lon
Hey I'm jose. Do you have a pic of how the latch mechanism is supposed to look like mine broke and I don't know how to fix it. (I'm talkin about the latch that keeps the back of the top from opening)
- thanks.
Old May 11, 2009 | 09:14 AM
litemup's Avatar
Gosh, I'm having the same problem with the release switch and to make matters worse one of the side cables is not there, so I can't put the top down at all, and it's 75 here today perfect for top down!
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Fronzizzle
Aug 17, 2015 02:52 PM
