RS vert
Old Jun 7, 2009 | 12:20 PM
1990RSVERT's Avatar
Car: 1986 IROC Z28
Engine: LG4 305
Transmission: Manual T5
RS vert
Ok guys, I have a 1990 RS Vert, 1 of 729, and im told quite rare with leather interior. I just put a new top an the car, and but cant get the vert cover release to work, it hasnt worked since i got the car. It has the selenoids and the switch on console...but that is a far as I got. So any help would be appreciated....Also, if anyone has information on the 1990 RS vert, I would like to hear it, been in these cars foe awhile now and have owned 6, LOVE THEM!!!!
Old Jun 7, 2009 | 12:27 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: RS vert
Chances are, the relay in the back by the trunk latch is bad. All the verts left the GM plant with the wiring and such for the power hatch release but ASC modified the wiring when they did the vert conversion to make that wiring release the tonneau cover instead. If that relay is bad, it won't work. Do a search, there is a lot of info about it, and I'm not 100% sure on it so best to get that info from someone with more experience.
As for the 1990 verts, they are like the coupes; a hybrid of 85-89 and 90-92. They have the same gfx as the 85-90 cars but the dash, gauges, and steering wheel of the 90-92. 1990 camaro production was the lowest of the whole thirdgen run because it was a short production year. There was only the IROC-Z and RS; when the IROC license expired, GM Brought back the Z28 for 91.
Old Jun 8, 2009 | 10:07 AM
1Aauto's Avatar
Former Sponsor
Re: RS vert
Welcome to the site. Sounds like a great car.
Old Jun 10, 2009 | 04:08 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Re: RS vert
I have the same car. When I got it it had the same problem.
There is an interlock on the top release system that prevents the opening of the tonneau while the car is in gear or when the trunk is open.
I traced the problem back to the trunk. There is a wire connection to the bottom of the trunk latch attached to a switch that detects whether the trunk is closed or not.
In my case the problem was that the wire had become disconnected. It has a quick connector so the fix was as simple as just plugging it back in.
You can believe that I danced a jig as soon as I saw the solenoids fire!
Good Luck!
Speedy
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
okfoz
Oct 13, 2015 02:19 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
tcarlos13
Sep 2, 2015 07:29 PM
