Latch problems with convertible cover
Old Aug 1, 2009 | 02:49 PM
dreydog19's Avatar
I have a 1989 Iroc Convertible. I'm not a car buff. I bought the car with the electronic latches for the convertible latch top and both tonneau cover latches working. Now they don't. I was wondering if there is a way for this to be fixed. Where is the electrical box for these mechanisms? Would it be a fuse be, is there a fuse? Also my boyfriend took the cotter pin for the middle latch apart to try and close it once. How do I put this back together with the wire mechanism? Pictures would be very helpful with instructions. I don't care as much about the electrical part, but I need that cotter pin thing to work in order to "catch" the top. Thanks a bunch!
Audrey
Attached Thumbnails Latch problems with convertible cover-pooper-camaro-008.jpg   Latch problems with convertible cover-pooper-camaro-013.jpg
Old Aug 1, 2009 | 02:56 PM
lv2bnmyz's Avatar
Car: 91 & 92 Z28 Vert
Engine: 91 305 92 383
Transmission: TCI Streetfighter 700r4
Re: Latch problems with convertible cover
Im in the same boat with the cotter pin puzzle. Some one help us out!
come on vert guys
Old Aug 1, 2009 | 03:02 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
heres the latch pics hope it helps my electric dosent work either
Old Aug 1, 2009 | 03:03 PM
dreydog19's Avatar
I think I answered my question about the latch. an earlier thread had a pic with a red camaro's latch that looked like it would help. look there. but i still want to know about the electrical part
Old Aug 1, 2009 | 03:04 PM
Engine: ls1 soon
pics courtesy of iroctopless
Old Aug 1, 2009 | 03:10 PM
dreydog19's Avatar
thanks a bunch, i don't know how i missed that pic or thread Do you have a pic of the electrical components by chance?
Audrey
Old Aug 2, 2009 | 02:35 AM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
i found that the saftey switch that doesn't allow the tonneau to open if the trunk is comes unplugged on mine a cple of time already maybe check that after u check middle switch for power, in the trunk below the lift motor behind courtseylight it is a white connector if i remember... there is also a wiring diagrahm on here somewhere for all of it btw i think it also has to be in park to open correct me if i'm wrong
Old Aug 2, 2009 | 02:42 AM
Engine: 5.0 tpi
Axle/Gears: g92 b/w
he said this
"The convertables used the hatch release wiring/circuit for the tonneau. The schematic is attached. Basically if you have a manual transmission the parking brake needs to be set or if you have an automatic it needs to be in park or neutral."
pic courtsey of chuck88iroc
Attached Thumbnails Latch problems with convertible cover-hatch-20release.jpg
Old Aug 2, 2009 | 10:20 PM
lv2bnmyz's Avatar
thanks
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
