Sub-Frame connectors for convertibles?
Car: 91 & 92 Z28 Vert
Engine: 91 305 92 383
Transmission: TCI Streetfighter 700r4
Where are the sub frame connectors for a 91 z vert? Keep finding ones screaming not for convertibles? Any help or leading the way appreciated.
Axle/Gears: 3.45, 3.27, 3.27
Re: Sub-Frame connectors for convertibles?
And you can put both the Alston SFC's and your favorite perimiter design SFC's that are made to fit a 'vert on the car at the same time. Put the Alstons on first, then tie the others into it if it has the type (as Spohn's does) with the cantelevered piece that ties into the front subframe.
Lon
Lon
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
just looking at these myself.. was going to go with the Spohn ones..
Do i need 2 sets?
Do i need 2 sets?
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Can you elaborate on this Lon or are there pics of what we need?
I haven't personally done the double SFC install yet. There are a few local members that have and many more here on Thirdgen.org. Do a SEARCH. Discussion and pictures of the installation have been posted.
Lon
Lon
Hotrodboba400
Dec 10, 2019 07:07 PM
