How do I remove this Piece so I can Repair/Replace it?
Old Sep 28, 2010 | 07:00 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
I am in the process of restoring the roof of my poor little 91 z28 vert'. Attached is two pictures of the piece I am trying to remove. Its the BROKEN piece that the back window guide/rubber attaches to, traditionally called a B pillar in a non vert. Anyone know the actual name of this piece?
Attached Thumbnails How do I remove this Piece so I can Repair/Replace it?-photo-0028.jpg   How do I remove this Piece so I can Repair/Replace it?-photo-0029.jpg
Old Sep 29, 2010 | 02:18 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Re: How do I remove this Piece so I can Repair/Replace it?
I can't answer your question but wow... did something fall on it?
Old Sep 29, 2010 | 09:50 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
LATCH YOUR ROOF BEFORE DRIVING AWAY! I had done stereo work the evening before and forgot to latch the roof... Next morning hop in the car to go to work... about 45 mph the roof folded back and that happened...
Old Sep 30, 2010 | 02:21 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
be careful trying to remove it because the shoulder bolt in the corner usually snaps. spray it down with pb blaster a few times before trying to break it loose. I may have that piece if you need it I will have to check for sure.
Old Sep 30, 2010 | 10:55 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
mine is missing the sholder bolt i replaced it with a different bolt thats stainless let me know if you have that piece
Old Oct 1, 2010 | 10:45 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Anyone? I am trying to do this without removing the roof fabric just yet
Old Oct 2, 2010 | 12:15 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Mitch, I work at a GM d-ship but we use a site that gives replacement info on several makes. Sometimes it works decent, sometimes not. I won't be at work long tomorrow but I'll see if I can sneak a peak in the am. If not, Monday I'll be sure and check then if you can't get any help if you want. 91 vert, guess there was only one design?
Old Oct 2, 2010 | 12:21 PM
jstoltz's Avatar
looks like I do have it. The shoulder bolt needs drilled out but at least it isn't in two pieces should make it easier. It is the passenger side, correct? I have driver and passenger side the drivers side is fine I bought these a few years ago to replace the ones on mine and never got around to it. anyways here is pics. Let me know. Thanks also you will need to remove some of the roof fabric but not much.just over the piece. I can get it down to just the piece you need but I need to cut the bolt. unless I can get it loose.
Attached Thumbnails How do I remove this Piece so I can Repair/Replace it?-vert-top-pillar-001.jpg   How do I remove this Piece so I can Repair/Replace it?-vert-top-pillar-002.jpg
Old Oct 4, 2010 | 11:22 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
No help from our GM site. Top is aftermarket, so to speak. There was a TSB on the latch.
Old Oct 4, 2010 | 03:44 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Thats cool thanks for looking!
Old Oct 8, 2010 | 09:06 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Had mine doen a while ago . . .
Do TSB's ever expire? Just wondering for owners who haven't had it done and their cars are getting older. I guess at some point parts might be an issue.
Old Oct 8, 2010 | 10:04 PM
jstoltz's Avatar
did you still need this or did you get another or get it fixed?
Old Oct 9, 2010 | 01:43 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Not sure if and when they expire, as far as recalls. Believe I heard restraint system problems were for life of car, not sure how they determine that. I know they got out of those paint delamanation problems by cutting the life of the paint. Started at 10 years I think and went to 7 then 5 just in a couple of years.
TSB's are always good. Lots of times they are updates to factory manuals or one I remember is to enlarge hood hinge bolt hole due to fender supplier differences.
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Glowsock
Aug 26, 2015 12:28 AM
3rdgenparts
Aug 8, 2015 07:09 PM
