Was there plans for a dash mounted tonneau release?
Old Mar 5, 2011 | 10:27 PM
TX T/A's Avatar
Car: 1992 Trans Am Conv.
While thumbing thru the factory repair manual I noticed one of the dash mounted switches was marked tonneau release,it was next to the fog light switch. That would have been cleaner and not so fragile like the setup we have now. 92 TA vert
Old Mar 6, 2011 | 12:34 AM
Keith5875's Avatar
Car: 1989 GTA
Engine: 5.7
Re: Was there plans for a dash mounted tonneau release?
Not sure, on my 1989 TA the trunk switch powers the tonneau cover I don't think that is factory but I sure do like it.
Old Mar 7, 2011 | 08:59 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The later cars used a switch on the tonneau cover IIRC. The early cars simply used the trunk release switch. The Non factory cars definitely used the trunk release switch. I am wondering if the switch was changed for the factory models, but I think they used the stock location.
Old Mar 10, 2011 | 01:18 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
mine was a factory 87 vert and it was the trunk switch
Old Mar 10, 2011 | 10:13 PM
iroczVinnie's Avatar
Car: 89 IROCZ vert
Engine: 305TPI
mine has a pic of the tornneau on the switch (1989 model), but i think the switch internals are the same as a trunk switch.
Old Mar 11, 2011 | 05:17 AM
jstoltz's Avatar
for my 87 it didn't have the tonneau pic it was just a white print hatch release switch not sure if it got changed out along the way to me though.
Old Mar 12, 2011 | 09:55 PM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
ive got an 85 iroc vert and i need to wire up my switch for the trunk and tonneau, can anyone tell me what color wires do what? so i can run them and do them the way i like?
im thinking about using the normal spot for the truck realese, but hiding the tonneau one somewhere under the dash or in the center console under the lid,
i really need to know the power wires for the truck realse cause theres about 7 wires back there running to it and i cant make heads or tails... along with the tonneau realese, theres only two wires black and red and i cant figure out where they run to, theres only one brown wire tunning to the center console that hooks into the sliding switch HELP!
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
smooth
Aug 18, 2015 06:34 PM
