91 z28 convertible lid popper question
Old Apr 5, 2011 | 04:02 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
my lid popper isnt working, its all new solinoids and things, just got the car....any hints on where to start diagnosing this?
Old Apr 6, 2011 | 04:28 PM
Car: 91 Trans Am
Engine: 355 TPI
Re: 91 z28 convertible lid popper question
i took a look at it and when i hit the botton to pop the latches for the cover i can hear the relay click but the selonoids don't do anything....is it possible that the wires on the botton are backwards?
do the selonoids pop in or out to pop the latch?
Old Apr 6, 2011 | 05:03 PM
Hiemarch's Avatar
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
they pull in to release the latch it is possible that you have your wires inverted.
Old Apr 6, 2011 | 05:05 PM
Car: 91 Trans Am
Engine: 355 TPI
towards the front of the car?
Old Apr 6, 2011 | 05:07 PM
Hiemarch's Avatar
yeah the solenoids pull towards the rear of the car
Old Apr 8, 2011 | 03:27 PM
Car: 91 Trans Am
Engine: 355 TPI
switch the wires around and nothing....i can squeeze the solinoids by hand so they aren't locked up
is there a fuse between the button and the solonoids?
Is it possible for the relay to click with the botton but not energize the solonoids?
and i assume these babies self ground since they are one wire?
Old Apr 8, 2011 | 04:06 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
The screws that hold the solenoid to the body of the car arethe grounds...And you can't assume the solenoids are good just because you can squeeze them.
Old Apr 8, 2011 | 04:09 PM
Car: 91 Trans Am
Engine: 355 TPI
im gonna borrow a power probe and see if i can energize them and ill report back
im just saying there not locked, i didnt say they were good
Old Apr 8, 2011 | 08:34 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
If the adjustments are set to pull the top in too much, the solenoids won't be able to release it. You can see if they work when the cover is raised manually, or try pushing down on the cover when hitting the button.
Kevin D.
Old Apr 8, 2011 | 10:19 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Kevin D.
Yeah, try pushing down on the lid when you click it. Mine sometimes does not release if I did not push the top in enough prior to closing the lid (it pressures up on the lid). Solenoids wont release it when the toneau lid is being pushed up from inside.
Old Apr 9, 2011 | 12:26 AM
Mark_Hardware's Avatar
Car: 1991 Camaro Convertible
Engine: Hellifi-no special
Check the trunk.
The wire goes from the relay in the center console, through a connector in the trunk, then back up to the solenoids. If this wire is disconnected, the relay will click, but the solenoids won't pop.
I believe this is supposed to keep you from opening the tonneau cover while the trunk is open. But don't quote me on that.
Wire from relay travels on drivers side back to trunk, back towards front of car on the passenger side, and splits to go to the two solenoids right behind the passenger side sail panel.
The wire carries a positive current while the button is pushed. The chassis (of the solenoids) is the ground.
First thing you should do is put a circuit tester on the plug to the solenoid. Does it light up when you push the button? If so, it's your soenoids. If not, check the wire, especially around the trunk latch.
Old Apr 9, 2011 | 08:48 AM
67tothefuture's Avatar
Engine: 305 tpi
Transmission: 700 r4 Auto
Mine does the same thing, sometimes I have to push the lid down, try this befor all the other work
Old Apr 10, 2011 | 10:37 AM
Car: 91 Trans Am
Engine: 355 TPI
fixxed it, there was about 4 and a half feet of bad wire from the solinoid on the passenger side to about half way through the trunk. replaced and they work but the passenger side one is a little slow....but they work
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
