Ground for amp?
Old May 26, 2011 | 12:48 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Ground for amp?
What ground are you guys using for your amp in the trunk?
Old May 26, 2011 | 01:04 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: Ground for amp?
I just pushed my carpet up in the back and sanded a small area down to pure metal and screwed it in. Then with the carper over it you cant tell its even there
Old May 26, 2011 | 03:17 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Ground for amp?
forgive me if i'm not too familiar with the verts, but I usually use the rear upper seat belt bolt. big solid piece of metal, just needs the paint sanded off for a good connection. cover everything with dielectric grease to stop moisture/rust and should be good to go
Old Jun 17, 2011 | 12:19 AM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Re: Ground for amp?
I dont think that will work on verts cuz' the rear upper seat belt attaches to the toneau cover I put a bolt through some metal behind the drivers side plastic trunk thingy
Old Jun 17, 2011 | 09:17 AM
cougar20th's Avatar
Car: Black 88 Iroc Convertable
Re: Ground for amp?
I believe mines bolted thru a hole in the rear quarter support struccture. But my amp is hidden where the little storage bin was.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
