Tonneau cover won't latch
Old Sep 10, 2011 | 07:08 PM
jstanfi1's Avatar
Car: 1992 T/A Convertible
Engine: LB9 305 TPI
Been reading all over this forum but can't find a problem quite like mine...my passenger side solenoid for the tonneau latch seems fine, in that I can push it to closed manually and it opens when I hit the release switch, but when I shut the tonneau cover it doesn't lock down. Looks/seems like it's hitting. Any ideas?
Old Sep 15, 2011 | 05:00 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Tonneau cover won't latch
If I understand you correctly, it sounds like the tonneau latch on the driver's side is stuck in the closed position even though the cover's pin isn't in it. The cover's pin is hitting the closed latch. Kind'a like trying to close the trunk lid down on a closed trunk latch. Not pretty.
Have you tried returning the latch to the open position by either using the switch, or if that isn't working, the manual release cable. You will likely need to emulate the cover's pin, as if it was in the latch, with your finger or maybe a screwdriver and lifting slightly while trying to open it.
Note; the intention is not to use your finger or screwdriver to "pry" the latch open, only to assist it in moving to the open position.
Good luck. Please reply if it sounds like I'm not reading you right.
Old Sep 17, 2011 | 03:07 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Mine did that and it was sticking. I sprayed it with some brake cleaner and cleaned it up and then poured some mobil one 90wt rear end grease on it and worked it around. I had to do my hood latch as well. I guess they all had the same amount of dirt and grime and decided not to work. My solenoid poppers work but would not release the top and now they do with a little help.
Old Nov 15, 2011 | 09:11 PM
jstanfi1's Avatar
Engine: LB9 305 TPI
Ok, so I finally got around to digging at this problem. Turns out the latch receiver is still working but I think it's just wore out....when I latch it I can still pry it back up with a screwdriver. The driver side I can't. So, any good source for a replacement? How hard are these to swap?
Old Nov 20, 2011 | 01:05 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
http://www.top-downsolutions.com/sho...rt.php?sort=5a
Yes I have some.
Lon
Old Nov 20, 2011 | 08:56 PM
jstanfi1's Avatar
Engine: LB9 305 TPI
Thanks Lon, I ordered the set. Any instructions you can provide on how to replace would be great.
Old Nov 27, 2011 | 05:21 PM
jstanfi1's Avatar
Engine: LB9 305 TPI
New problem if anyone can help (Lon?)...got the receiver replaced but it looks like the cable is damaged as well. I think someone had messed with this before...
Anyhow, where do I get a new cable?
Old Nov 27, 2011 | 09:42 PM
lonsal's Avatar
I'll check if I have some.
Lon
Old Jan 4, 2012 | 10:33 PM
jstanfi1's Avatar
Engine: LB9 305 TPI
Just to close this thread, it turned out the locking pin in the latch receiver failed. The actuator and cable turned out to be fine once I cleared an obstruction caused by a prior speaker install (for once not my mistake!!!). Tonneau latches perfectly again and I eliminated an obnoxious rattle in the process.
75 days 'til spring!
Old Mar 27, 2022 | 02:52 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I know this is an old thread, but I am having the same issue and need a replacement latch for the passenger side.
does anyone know where i can get one?
Thanks,
Chris
Old Mar 27, 2022 | 07:17 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Here, FB or ebay are only places i can think of.
Old Mar 28, 2022 | 07:37 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Might Try Hawks, or one of the 3rd gen junkyards... you never know what they have. Chances are you will have to do with used. Not sure but I would bet 86-91 would be the same, or similar enough to work, 92 might be different, but maybe not... Without looking into the parts manual..
Thanks,
Chris
Old Mar 28, 2022 | 01:00 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Thanks,
Chris
I’m pretty sure I have a few of those
V8SC1987
Convertibles
Oct 5, 2015 01:51 PM
claytonjn
Convertibles
Feb 11, 2011 08:17 PM
9340Ruby
Convertibles
Jan 23, 2011 05:05 PM
91Z28
Convertibles
May 22, 2005 12:01 PM
