Tonneau Latches
Tonneau Latches
My tonneau cover will not latch. The latches close but the slightest tug and thy pop open. I've pulled the release levers off the latch completely to eliminate all that stuff. Do I just need new latches? Can thy easily be rebuilt by a DIY'er?
Randy
Randy
Car: 1992 T/A Convertible
Engine: LB9 305 TPI
Re: Tonneau Latches
I was having the same problem a few months back and wound up ordering a used set from Lon at top down solutions. I saw no easy way to rebuild them, but you might be more gutsy than me. Good luck!
Axle/Gears: 3.45, 3.27, 3.27
Re: Tonneau Latches
It could be that the body has flexed (twisted) with age and the J-hookk is not protruding far enough down to properly latch. You'll need to shim the J-hook so it goes down a bit further. Just remove it and either make a shim from some sheet metal to put under the hook or buy some door shims from the HELP section of the auto parts store to shim it. I have sees some J-hooks that came shimmed from the factory.
Lon Salgren
626-369-0040
Lon Salgren
626-369-0040
Re: Tonneau Latches
Thanks Lon but the hinges were just worn out. I removed them and tested them off the car with a screw driver. I ordered a set from you last week and they did the job. It was a pleasure doing business with you!
If you can rebuild them I will send you the old hinges as I have no use for them. I don't know how hard the latches are to come by and am willing to do my part to keep these parts available.
Re: Tonneau Latches
I do not rebuild them. I have a few sets in stock.
Lon Salgren
626-369-0040
Lon Salgren
626-369-0040
Re: Tonneau Latches
OK, Top-Down Solutions new and improved web site is FINALLY up and running. Thanks everyone for your patience.
Lon
Lon
1992 Trans Am
May 10, 2023 07:19 PM
