Mr. IROC-Z
close
Baby got a new top. She had the original top since 1990. The original top was in great shape for being over 20 years old but the plastic window was bad. The plastic window was faded and yellow even though the car has been garaged for all of its life. In any case, the new top is awesome with a glass window! feels great to see from my rear view mirror now!
Did you do it or professional install
Looks like a show room new car!!
Seen your car before on here and its a beauty and with that new top looks amazing
Mr. IROC-Z
close
Quote:
Hi There,Originally Posted by Benc1
Did you do it or professional install I had the shop order the top and do the install. I don't think I would have the patience to this job myself.
It is hard to get the crease out of the left hand side at the window. He did a great job.
Quote:
Yeah that is the reason I asked the creases are virtually non existent on his install. Still haven't figured out how to get rid of them.Originally Posted by yankeecarman
It is hard to get the crease out of the left hand side at the window. He did a great job. COTM Editor
BADNBLK
COTM Editor
close
Nice man! Looks great!
Looks real nice I am also in the Bay Area what is the name of the shop and how much did it all cost? Do you have the inside liner?Originally Posted by Mr. IROC-Z
Hi There,I had the shop order the top and do the install. I don't think I would have the patience to this job myself.
What brand top is that and have to see if he will give up the secrets on the top install,,,looks great by the wayOriginally Posted by Mr. IROC-Z
Mr. IROC-Z
close
Quote:
Discovered why there are no creases in the top...the top material is stretched to the limit when it is latched into the body. In fact, I struggled for almost 30 minutes before I could put the top back up! I am not sure if the fabric needs more time to stretch? The install guy did say that I should keep the top up for for about a week, but I just played it off...lol. If I still have issues by the end of the week, I will need to take it back to the shop. Originally Posted by Benc1
Quote:
Installed a top on a friends mustang a while back. The top does need to remain up for at least a week. This allows the fabric the stretch and the glues to fully cure. Believe it or not it will stretch and it does take time. My friends mustang took almost 3 months out in the sun before it stretched enough he didn't feel like he was forcing it down. We've had to adjust (Tighten the latches) a couple of times since then because the fabric has stretched. I guess the moral of this is it will stretch. I looks like a very clean job done by someone who knew what they were doing, just trust it will stretch and try not to put it down until that week is up.Originally Posted by Mr. IROC-Z
Mr. IROC-Z
close
Quote:
Originally Posted by Da Spudro
Installed a top on a friends mustang a while back. The top does need to remain up for at least a week. This allows the fabric the stretch and the glues to fully cure. Believe it or not it will stretch and it does take time. My friends mustang took almost 3 months out in the sun before it stretched enough he didn't feel like he was forcing it down. We've had to adjust (Tighten the latches) a couple of times since then because the fabric has stretched. I guess the moral of this is it will stretch. I looks like a very clean job done by someone who knew what they were doing, just trust it will stretch and try not to put it down until that week is up. Thanks for the tip!
is that hood pins on your hood?
Nice vert..Love the way it sits..If you dont mind me asking..What kind of suspension do you have..I would like to rebuild mine,and dont know where to start..thanks..
Mr. IROC-Z
close
Quote:
I don't recall what brand TOP it is. I just had the shop order the best model that matched the look of the old top but available with the glass window. Interestingly enough, there are two different sizes of tops for cars from 1988-89 and 91-92.Originally Posted by 86gn
Do you know what brand top it is? Quote:
Yes, those are Aerocatch hood pins.Originally Posted by zenish
is that hood pins on your hood? Quote:
The springs are 'custom cut' from Global West. The fronts are rated at 900lbs and the rear at 160lbs. It sits on Koni Yellow shocks. I have the stock A-Arms. The entire suspension has been rebuilt with Moog, and aftermarket parts.Originally Posted by gpasare
Nice vert..Love the way it sits..If you dont mind me asking..What kind of suspension do you have..I would like to rebuild mine,and dont know where to start..thanks.. Member
Now i want one for mine are there red tops?
Well it looks GREAT on your car and Im going to be needing one myself. If ya get time and don't mind calling the shop that would be great. I THINK the differences in the tops between the years is ones with and without the headliners
[QUOTE=Mr. IROC-Z;5605053]Baby got a new top. She had the original top since 1990. The original top was in great shape for being over 20 years old but the plastic window was bad. The plastic window was faded and yellow even though the car has been garaged for all of its life. In any case, the new top is awesome with a glass window! feels great to see from my rear view mirror now!
Props man...one of the cleanest 3rd gens I've seen. Makes me want a vert...nice job homie
That top looks great. My top is almost to the point of needing replacement and I'm pretty sure that I want a glass window. I'm just not sure how that would work out as my top seems to fold in the middle of the plastic window. Is the glass window positioned differently or is it smaller? That top really does look good. Any other info you can give on it would be a big help. Thanks!
