1989 camaro iroc z28 vert chassis flex
Old Oct 19, 2013 | 11:25 AM
dss42186s's Avatar
Car: 1989 camaro vert
Engine: 305tpi/350tpi
Transmission: tr700
I kno their are many posts about this but I want to put a 350 or 383 in my vert but what do I need to do so i dont twist the car in half
Old Oct 19, 2013 | 06:45 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 1989 camaro iroc z28 vert chassis flex
https://www.thirdgen.org/forums/susp...questions.html
Old Oct 31, 2013 | 09:02 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Don't hit the gas too hard.
My Formula 350 convertible has no problems... It is a stock engine, I do not plan on modifying or upgrading it either... Actually it probably squeaks less than almost any other 3rd gen I own.
Old Nov 5, 2013 | 03:04 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Mine has the stock 305 tpi but I have stiffened up the suspension with all the lower control arms and all red sway bar and trans mount bushings, bilstein shocks, the works. It drives almost like a go-cart now and cracked the windshield the first time I took it around a good corner. I dont have sub frame connectors yet but that is on the list. I am going with a mild 350 since it will be a cruiser the rest of its life. They really do flex quit a bit.
Old Nov 6, 2013 | 08:43 AM
okfoz's Avatar
I will admit that yes they flex... Just take it down my driveway...
Old Nov 6, 2013 | 10:24 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
I've made a few hundred track passes with 600-800hp..most were leaving violently off the transbrake.. It has Southside machine subframe connectors and a beefed up 6 point rollbar welded through the floor ONTO the subfames.. The rear lower control arms are tied into the subframe connectors also hich really helps get the power into the "chassis".. These cars are flimsy, thats a fact. The convettibles have some additional support but more is needed. Mine has never wrinkled the quarter panels, thankfully..
Doing just beefy subframe connectors helps a lot and actually makes the car stronger in a crash situation.. My SSM subframes were welded into my t top car 3 days before I totalled it.. I t boned a truck that turned in front of me. All of the front end damage stopped at the doors.. The gront portion of the subframes... We cut them out and they are now on my vert!
Old Nov 6, 2013 | 10:27 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Put it in and enjoy.
Unless car is very rusty, you won't have a problem.
Subframe connectors are a must on any 3rdgen that will be driven.
Old Nov 8, 2013 | 03:23 PM
blakecharles's Avatar
use outter SFCs - UMI or Jegster
and inner SFCs - MAC or Alston
this will stiffen the car up quite a bit, dual SFCs may be a bit of overkill.... Maybe you can install 1 set and see how you like it. If you want stiffer, install the 2nd set.
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Rustyweb7
Aug 9, 2015 03:05 AM
antares57
Aug 6, 2015 07:47 AM
