another water ingress thread
Old Feb 19, 2014 | 10:55 AM
droptop_ta's Avatar
Car: 92 T/A vert
Engine: 305TPI
Hi guys I could do with your collective expertise on my problem , as I've done the usual search but I'm still at a loss.
Firstly I have fitted a new bow seal and as you can see it doesn't seal against the body on the driver's side just aft of the side glass and also at the rear lock pin as per the photo. Now as you can see in the photo of my trunk it is full of water although strangely only under the carpet! I can see by the marks on the tonneau seal that it seems to seat okay and also the same with the trunk lid, the trunk side wells and all around the trunk inner is dry only the center well and a bit at the top each side of where the seat belt reels go behind the rear seat. Is it possible my frame is out of alignment since the bowseal front ends don't meet at the side glass seal so I can see daylight from inside. Many apologies for the long post but I wanted to be as precise as possible and not create multiple threads.
Thanks in advance.
Attached Thumbnails another water ingress thread-dscf3218.jpg   another water ingress thread-dscf3219.jpg   another water ingress thread-dscf3223.jpg
Old Feb 20, 2014 | 11:03 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: another water ingress thread
With that much water you shouldnt have a problem finding the leak maybe you could get in the trunk and have a friend spray a jet stream of water all around the trunk top and tail lights and you should find the leak good luck
Old Feb 21, 2014 | 04:42 AM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
try cleaning the tubes that take the water from the run off sections around the trunk to the bottom of the car on the inside. I know that isnt clear but I dont know how to explain it. There are tubes inside the section where the sizzors are mounted. Tubes take the water to the bottom of the car and then there are holes that take the water out of the sections. Hope you understand and I hope it helps.
Old Feb 21, 2014 | 05:03 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Though I don't have a convertible, I used to have a similar issue.
In the end I replaced the hatch seal with a new one, so maybe it's that.
Otherwise, if you can get into the trunk like suggested by Mirror Image, that's the way to go.
Old Feb 21, 2014 | 09:25 AM
droptop_ta's Avatar
Car: 92 T/A vert
Engine: 305TPI
Thanks for the replies, Yankeecarman I know exactly what you are referring to. In fact I cleaned out the outlets in the bottom of the fenders last year due to a waxoyl blockage. The passenger side however still has water in the channel along the side by the tonneau so it's not clearing there it seems, also the tonneau seal is in three parts with slight gaps at the two corners is that normal?
Old Feb 22, 2014 | 08:01 AM
galletti's Avatar
Car: 1988 IROC Convertible
There's an old trick that can help. Find a way to create a safe source of smoke inside the car while all doors, top, and trunk are closed. I used some incense. When the car fills up with smoke, it will be a little out of where you have leaks.
Old Feb 23, 2014 | 06:35 AM
droptop_ta's Avatar
Car: 92 T/A vert
Engine: 305TPI
I would try the smoke galletti but my car would be sending up smoke signals from everywhere as my top seals have plenty of gaps!
Old Feb 23, 2014 | 08:18 AM
galletti's Avatar
Lol! I agree this method is usually for more subtle leaks.
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tommy z-28
Oct 6, 2015 10:58 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
