SPECIAL EDITION CONVERTIBLES ASC ONLY PLEASE
Old Mar 22, 2025 | 04:38 PM
  #101
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: SPECIAL EDITION CONVERTIBLES ASC ONLY PLEASE
Originally Posted by Airwolfe
Wow the stiffening bracing is nice.
Yep, so is that properly covered Recaro seat!
Old Mar 23, 2025 | 07:40 AM
  #102
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I had to look at it a couple times to notice it was a Recaro seat.
Old Mar 23, 2025 | 08:56 PM
  #103
Airwolfe's Avatar
@Helosixx I don't know what kind of spiffing up under the hood you plan to do but a new coolant overflow tank and washer fluid tank would spiff it up nice. Swapping the 89 down style driver side valve cover for a 90 up style valve cover would help with oil changes too. It puts the oil fill at the front and the PCV valve at the rear.
Old Mar 26, 2025 | 12:21 PM
  #104
Helosixx's Avatar
Great idea, will look into that. It's not had much use and the tires while still plenty of tread where a little hard. Switiched them out this morning... the date code on the old set was 110 (that 11th week of 90') =)
I've attached another image of the frame brace from behind the front wheel. Really cool work for sure.
Thank you again for the suggestions.
Old Mar 26, 2025 | 01:11 PM
  #105
Airwolfe's Avatar
I'm a bad boy.
I want to 3D scan your car then take it apart and 3D scan all the chassis stiffening on it.
Old Apr 15, 2025 | 09:01 AM
  #106
Helosixx's Avatar
Just posted for sale https://www.thirdgen.org/forums/cama...en-camaro.html.
Call with any questions, Thanks!
Old May 23, 2025 | 12:17 PM
  #107
89camvert's Avatar
Just picked up an 89' RS Convertible.
When you look up the vin it says it started life as a Iroc Z. It has the ASC label on the driver's door and was finished in February of 89'
My vin is: 1G1FP31E5KL159673.
The 6th digit is a 3, so is it an 87' that was an anniversary year and wasn't finished until 89'?
Old May 23, 2025 | 03:05 PM
  #108
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Nice, that would be a "Factory" conversion. Made same place, same process, the 3 indicates a "Convertible" The Conversions show a 2 for "Coupe" Years are as follows
G = 1986
H = 1987
J = 1988
K = 1989
Old Aug 2, 2025 | 08:35 PM
  #109
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
@Helosixx I ... .... Swapping the 89 down style driver side valve cover for a 90 up style valve cover would help with oil changes too. It puts the oil fill at the front and the PCV valve at the rear.
Interesting! My 1989 IROC Z LB9 , 305TPI had the oil fill cap, on the Right (passenger) side, somewhat blocked by hoses, and whatnot. And the PCV on the Left side. I assumed a mechanic did Valve Cover gaskets and put the covers back on the wrong side! So I installed new VC Gaskets and reversed the covers. Did the Factory build my 305 w/ the oil filler on the Right?
Anyone?
Old Aug 2, 2025 | 08:57 PM
  #110
Helosixx's Avatar
Anyone?
I'm really not sure. My car was an internal car at ASC so there is lots of custom stuff done. The engine I'm told was swapped from another test car they destroyed and is a balanced and blueprinted Traco 5.7L race motor. One of the higher ups was authorizing the work which had no possible ROI.
Should be pretty easy to look up past sales of 89' Irocs and compare the engine photos posted to your setup.
I have Ferrari's, Porsche's and Vettes... keep in mind it doesn't matter who builds the car, when the assemble line runs low on parts they will use whatever they car get their hands on to keep production going. Very normal for a few cars in a production series to have different parts, fasteners or whatever. Hope this helps.
Old Aug 2, 2025 | 09:43 PM
  #111
Airwolfe's Avatar
Anyone?
I can't speak for the 86 and earlier TPI F-body cars, but I think the oil fill has always been on the (left) driver's side of the car. Barring some "race cars" GM got smart and put the oil fill cap in the front with the PCV in the back on the (left) driver's side, and the CCV on the front (right) passenger's side starting in 1990.
The 1990+ setup is the way it always should have been for TPI cars. Oil fill cap up front and out of the way of everything.
sgeorges714
Convertibles
Jun 9, 2025 01:29 PM
86WhiteHeat
May 30, 2014 08:51 AM
86WhiteHeat
May 29, 2014 08:13 PM
razor
Jul 17, 2002 09:06 PM
