Is it worth buying?
Old Dec 8, 2017 | 10:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Is it worth buying?
Considering the condition.Kinda tempted, but.........
https://www.ebay.com/itm/1991-Chevro...BaKoPv&vxp=mtr
Do these braces look fine? Are they screwed on or? Not too knowledgeable on topless 3rd gens here.
Old Dec 9, 2017 | 06:29 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Is it worth buying?
Did somebody pick that up with a forklift?
Old Dec 9, 2017 | 12:05 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I'll say this. That dealer takes fairly crappy 3rd gens and sells them for a lot of money. It's strange that they only want $4K. They usually ask 10K more for a car like that.
The fact that THEY are selling it that cheap makes me say buyer beware. Do your due diligence.
Old Dec 9, 2017 | 02:17 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats what i kept thinking while reading thru it.Do those braces come off easy?
Old Dec 9, 2017 | 02:25 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
If your goal is to get a really nice Z28 Vert I personally wouldn’t want one that’s been hacked up and painted metallic bubble gum with strange designs on the sides..
There’s a couple nice ones up my way for $6k-8k with around 90-120k miles that are still original and not hacked up..
That car will need a top and If I bought it, a re-paint.. I’d also put aside $2000 for potential mechanical repairs..
I’d spend a little bit more and get something a huge bit better.. you’ll save money in the long run..
Old Dec 9, 2017 | 09:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Just looking at those pics was enough to keep me away, but it was tempting at that price.
Did they rivet those things on? Whats with the screws on em?
Old Dec 10, 2017 | 09:48 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The subframe connectors they came with from the factory are riveted on steel with a ton of seam sealer over them. The thickness is less then 1/8", I'd guess 14 gauge.
If that car has a clean title, starts and drives fine and you liked the paint I would say it's a good deal. There doesn't appear to be any rust and panel alignment is good--That's half the battle when looking for a good thirdgen, especially in a convertible. This car seems to need some rebuilding though. Top needs replaced, engine at 138K miles would need rebuilt, trans probably too. There has been some hackery as evidenced by the added buttons below the stock window switches so there could be more hiding elsewhere. The dash pad needs replaced, the door panel upper molding needs replaced. The seats and carpet look clean and dingy at the same time.
dramier
Oct 10, 2001 12:31 PM
1991camaroRS
Jun 29, 2001 02:23 PM
Phillip
Mar 11, 2001 05:06 PM
Tallboy
Jan 13, 2001 10:57 PM
