89 CAMARO CONVERT POWER SEAT MOTOR
Engine: LB9 305
Transmission: AT
Re: 89 CAMARO CONVERT POWER SEAT MOTOR
Can'r answer your question. You might want to remove the switch assembly and see if the orange wire is getting 12 volts. I think the black is ground, check for good ground and the connector under the seat for corrosion. I assume your seat is not functioning in any mode?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There's actually three motors on the power seat track, so if nothing is working small chance all three went out together.Check those points as mentioned above.There is also a circuit breaker in the fuse block.
yo soy el warg
Convertibles
Dec 8, 2007 09:14 PM
BrianI
Aug 26, 2003 08:44 PM
chevyboy07 91
Jun 11, 2002 03:49 PM
